Thread: Pool return question
    Jul 2007
    Katy, TX
    188
    My first post and I hope I am posting in the tight section. I have an~ 13,000 inground pool. DE filter, intelliflo 4 speed pump, intellichlor, SWG with bubbler, weeping waterfall and spillway from spa. I have a question about the returns in my pool. I have 5 returns. When my pool is running at 2200 only 2 of the returns work with a nice strong flow and another one just barely comes out. When my booster pump is on I have really good flow out from 3 returns and barely anything out of the other two. However water does come out of the bubbler valve when bubbler is turned off (just a stream of water) at 2200. I just "assumed" that at normal run at 2200 and even when my cleaner is on for 2 hrs at 2500 (same returns at 2200) that ALL 5 returns would be working. Can someone tell me what is "normal". I do not run my booster pump on a long, reg. basis. Maybe an hour a day. Thanks so much!
    ~Andrea
    ~Andrea
    24,000 IG with spa and 4 ton waterfall. Equipment: Pentair 520 Clean & Clear, Pentair VS+SVRS Intelliflo, Pentair Whisperflo 2 HP, Polairis Cleaner, Intellibrites, Pentair Rainbow 320 in-line Chlorinator, Pentair Easy touch 8 wireless and spa side remote.
    Ft Lauderdale, Florida
    1,462
    Probably just not enough flow to get good circulation at that speed.
    I would venture to say that you're probably getting the good flow out of the return jets closest to the pump too, right?
    If so, you may want to consider using smaller return jet sizes. Your return jet should be a ring holding in a orbital piece with a hole in the center. There are various size holes.
    You can use smaller sized holes, called oraface, to influence more flow to the other jets.
    If they are Hayward return jets (there should be a part number on the ring holding the jet on with an SP-xxxx number. If so, you have the option of using part number SP-1419-A (slotted), B (3/8"), C (1/2"), D (3/4"), or E (1").
    Hope this helps.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Also, check to see if the returns are all independantly plumbed from the equipment pad or are in groups sharing a pipe. If they are all run seperately you might have valves that allow you to adjust the relative flow, or could add such valves. If they are sharing one or two pipes then you can use smallers eyes on the ones closer to the pump to balance them out.
    Jul 2007
    Katy, TX
    188
    Thanks for replying. Is there any harm in leaving it the way it is? I do believe they are plumbed from the same pipe and YES the 2 closest to pump are the ones that go full force. So, I can just unscrew the returns? They are fairly large, I can place two fingers in them. I will need to contact my builder to find out what brand they are. Thanks!
    ~Andrea
    ~Andrea
    Yes, they simply unscrew. You might need a strap wrench to get them out or they might only be hand tight. Of course you should turn off the pump before trying to unscrew them. The threaded holes tend to be a standard size so you can probably use a different brand.
    There only real reason to balance them is to improve your circulation. If you are happy with the way your circulation is now there is no harm in leaving it alone.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Andrea, poolsean has the right answer for equalizing the pressure from the returns, sounds like they were run off on line in series - as opposed to being run to a center point and then having the plumbing 'teed' in such a way to create ~ = pressure to all the ports. If it were me, I'd put 1/4" oriface on the 2 that are now pushing strong, a 1/2" on the next and 3/4" on the next and possibly the last, though the 1" I think would work better on the last. The smaller orifaces on the first pipes will produce back pressure to help better feed the later ones. If you have any trouble getting the 'seats' out of the returns, and thay are Hayward, the correct tool to remove them is SP 1419- T.
    Luv& Luk
    -Ted
