Thread: Booster Pump Problem
    cws91's Avatar
    Nov 2009
    Baton Rouge, LA
    15
    Hi All!
    I'm glad I found this forum but wish I had sooner.
    I purchased my home with an existing pool in May and have had a crash course on pools but think I've done pretty well. But as with anything, I don't know all the tricks of the trade and I'm sure this forum will help.
    That being said, please excuse my "newness" and bear with any dumb questions I may pose. One may be my current situation.
    My booster pump is not kicking on when i flip the switch at the controller. I don't hear a humm in the motor to suggest freezing. I flip the switch and nothing. Water is flowing through the system as I can feel the flow generated by the main pump coming from the outlet in the pool. Help! I don't want to assume that I need a new booster pump when I don't. And don't want to call the pool guy if there's something I'm not thinking of. BTW the pool is about 4 years old.
    Any help/suggestions are greatly appreciated!
    21,000 gallons
    Pentair 420 Clean & Clear Plus Cartridge Filter - Filter Area: 420 - Design Flow: 150
    Inground Plaster
    Pentair Whisper Flo Pump - 1 HP - Model CCP420
    Pentair MiniMax NT Series Pool Heater
    Aqua Rite Electronic Chlorine Generator
    Polaris 280 Cleaning System
    Vero Beach, FL
    462
    Re: Booster Pump Problem
    First, check to see if a breaker is tripped. Second, get a meter and check if power is even getting to the motor and then if it is even at the switch. Without knowing the specifics, I can't help much beyond that.
    BTW, do you get to the LSU games? My uncle is the announcer at Tiger Stadium and my mom played for the women's BB team years back.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    cws91's Avatar
    Nov 2009
    Baton Rouge, LA
    15
    Yep checked the breaker. I was hoping it was a switch or something that needs to be reset.
    Yes I go to pretty much all the football games. Dan Borne? He does a good job. I actually played baseball there back in the day.
    Geaux Tigers!
    21,000 gallons
    Inground Plaster
    Vero Beach, FL
    462
    Do you have a meter to check for power at the switch and pump? If not, you could try hooking up the pump to the good circuit that the main pump is on and try.
    Yep, Dan Borne'. Small world. I grew up in Thibodaux and we used to go to all the home games. What great energy at that stadium. My family was there for the baseball championship ring ceremony last weekend at the new Alex Box stadium.
    Solar heat
