My Hayward Super Pump 1H replacement arrived yesterday on warranty. The old one still works but it is leaking quite a bit. It isn't making more noise, and it is pumping. I will attempt to replace the seals after I install the brand new pump, but my query is some funky wiring. It seems that the old pump's jumper is set for 230v....[Hayward factory sets their SuperPump's for 230v]. The breaker is a a double pole 15 plus 15 amp. But the pump is wired using 3 wires and the plug end is a normal 3 prong plug [110/115v].... Which is unusual, or I think it should have a 4 wire cable and a proper 230/220 volt plug and receptacle.
Before I subject the brand new pump to this configuration I want to make sure it won't compromise the new pump.
On another note the old pump lost prime and when the power came back on after an outage the pump may have run dry for awhile until it self primed.
