Goldine Actuator - Adjustment...
taekwondodo
419
How do you prevent a Goldline JVA from turning 180o when "on"???
I need more like 90o when "on", +/- 15 or so degrees... (hate the way they plumbed the Ray-Vac... ahead of everything in the circuit...).
- Jeff
Remove the handle, remove the 4 smaller screws, remove the cover. There are two cams that activate micro switches. One for turning left, one for turning right. Adjust the cam positions as needed. Use the on board toggle switch as needed to test. Replace the cover and screws when done.
Scott
PoolGuyNJ
By giving back freely that which was given to you freely is both good karma and good for the soul.
posting.php?mode=reply&f=5&t=17849#
It had been a while since I was here contributing. I've been on Gardenweb's pool forum. I will try to be here more often. Now that my season is all but done, I have more time to get the ones that need help and advice from a technical point of view.
I don't always pick the easy ones.
Scott
PoolGuyNJ
