Thread: Cleaning Pentair FNS Plus DE Filter
    This morning i hopefully took another step towards pool maintenance independence by disassembling and cleaning my FNS Plus DE filter. This was all pretty straight forward although there were a couple things that i puzzled over.
    The biggest one was the bottom piece. There didn't really seem to be anything that indicted the correct orientation as it sits in the bottom. I just tried to align a couple of the plasic parts that appeared like they should sit on top of each other.
    Additionally, the top manifold has to go on in a manner to fit the large outlest pipe, and with the two center rods, i think it has to orient itself correct. IOW, i dont think you can put it (the bottom) in wrong and get everything back together.
    Also i wasnt positive as to how long to keep turning th ebolt on the outside retainer. The instructions said to do it till the spring coils touch, which i did, but it seemed like they touched fairly quickly. I probably have 3/4" of thread sticking out of the bolt.
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Cleaning Pentair FNS Plus DE Filter
    Quote Originally Posted by Thinkly
    I think from another thread you posted that you were bringing the filter inside... probably doesn't matter until spring reassembly whether or not the retainer is correctly seated. BTW on my cartridge filter it takes many, many turns of the bolt to get the spring coils to touch... it's a PITA
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
