Results 1 to 8 of 8
Thread: Blowing Lines with C02
    I closed my pool Friday, and was interested to see that the pool guy used co2 to blow the lines. He poured antifreeze in each line after blowing water out and then blew until pink antifreezed came out of returns, skimmer, and drains.
    I had never heard of using co2 before.
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    South Central NJ
    3,192
    Re: Blowing Lines with C02
    A properly sealed line doesn't need antifreeze.
    If he can get CO2 for cheap, it's no different than using a blower.
    Owner of - PoolGuyNJ LLC
    PVille's Avatar
    May 2009
    Purcellville,VA
    39
    I use my shop vac to blow the lines. Works much better than my compressor because of the volume of air moved.
    In ground 15 X 33 10,400 gal. Fiberglass
    Two Returns, Two main drains, One skimmer
    Aqua Logic SWG, Hayward TriStar 1.5HP
    Hayward C3025 (325 sq /ft) Cartirdge Filter
    Solar Heater (Details at http://www.bakerlabs.com/solar)
    I might add that $20 of c02 use was passed on to me the customer.
    10,000 gallon
    NC KANSAS44
    South Central NJ
    3,192
    He charged you for the CO2? That is outrageous! He doesn't have the tools to do the job right, buys CO2 to act as his blower, then charges additionally? What did he expect, you to supply the blower so that he didn't use the CO2? That is so wrong!
    Scott
    PoolGuyNJ
    Mar 2007
    Coastalish 'down easter'
    4,160
    Quote Originally Posted by PoolGuyNJ
    Scott
    PoolGuyNJ
    I gotta agree with that!!
    However, if he had used N2O and you were properly placed near a return, it'd be worth the $20
    Luv& Luk
    -Ted
    South Central NJ
    3,192
    But Murphy's law would bite you. You'd fall in the pool. Cold water is a definite buzz kill.
    Scott
    PoolGuyNJ
    Mar 2007
    4,160
    OK, then tarp the skimmer... and laugh
    Luv& Luk
    -Ted
