Any tips for cleaning LQ for winter?
I have WS or scale on inside walls at the bottom half where liquid chlorine collected. Not at the top area where the chlorine was diluted
I imagine there may be some build-up / scaling on inside of tubes and valves. (Although maybe not since i didnt have scale on upper part of LQ)
I was thinking of soaking everything in some type of diluted acid solution
Any guidance?
PS on different item: to store for winter, rubber o-rings, should one use teflon spray or silicone grease? I have seen both mentioned in different posts
Any guidance?
