Hi everyone. I've been lurking here for a couple of years trying to do my research before purchasing a pool or swim spa. Now the time has finally come and I have a 17' ATV 17 Sport on the way (unfortunately it won't be here until October). Per the manufacturers specs it should be approximately 2400 gallons. My plan is to keep it around the 85 degree mark on temp. It will be covered when not in use, but I plan to swim daily and I have a 5 year old and twin 4 year olds.... so I know that I'm going to have high bather load at times. I think I'm leaning towards adding 50 ppm borates and using the Dichlor then bleach method.
I would love to hear from other swim spa users what their experiences have been maintaining the water and what method they are using. I am located pretty close to a lake, so I would like to minimize the frequency of draining the swim spa as much as possible to avoid any chance of contamination. Also... for those that have been successfully maintaining their swim spas: What number goals have you used and do you have any advice on things for a new swim spa owner to watch out for?
ATV Recommends:
FC - 2-3 (Ozonator installed)
pH - 7.4-7.6
TA - 80-140
CH - 200-300
CYA - (No Recommendation) - I'm leaning towards 40
Borate - (No Recommendation) - Leaning towards 50
Based on Pool Math, these numbers seem to be a little closer to a fiberglass pool than a hot tub?
Again... I have plenty of time to finalize my targets. Just trying to plan ahead and gather as much information as possible.
ATV Recommends:
pH - 7.4-7.6
TA - 80-140
CH - 200-300
