Thread: Pool overflow with rain
    tedinelkgrove's Avatar
    Jul 2009
    Elk Grove, CA
    98
    I am here in Sacramento area getting pounded with rain. First since we bought house back in May. I assumed there was an overflow line (looks like a return that has a white piece of pvc connected protruding out of the grass about 2ftfrom the edge of the pool). What if that is not what I thought it was? The water level is just at the opening of the suspected overflow tube. If the water doesn't drain, is it OK to let pool overflow?
    ~15000 gallon inground, plaster pool
    Jandy CL460 Cartridge Filter Tank, Jandy Stealth SHPF 1.5hp pump, Pentair Legend II cleaner
    Leslie's DPD Complete Test Kit, TF Tests FAS-DPD Chlorine Test Kit
    Heliocol solar pool heating (HC-40 x6)
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Pool overflow with rain
    Quote Originally Posted by tedinelkgrove
    Tell me about the weather! (See ok-now-you-can-laugh-t17658.html)
    When my new pool was finished and filled, I checked the overflow pipes (2 were installed) with a garden hose -- both of them had been dead-ended into concrete/dirt by the subs, so they were non-functional. Pool builder had one of them chiseled and dug out (from beneath the deck) so now have that one tied into my drainage system. It's been needed only a couple of times. Today was one of them.
    Though my pool has never overflowed from top of coping, if it did the water would travel to a deck-o-drain on the patio or off the sides and be captured eventually by one or more of the surrounding landscape drains. If for whatever reason you think the water would flow into your house, you might want to get out there today (before dark) and test your overflow pipe as I did.
    good luck
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Jul 2009
    Elk Grove, CA
    98
    I can't read your link. The rain is crazy. I drove to Roseville and back to EG this morning. What a nightmare.
    Thanks for the fast reply. My patio drain should handle it if it overflows. I guess I can always drain some water at the filter tank on side of house.
    Do I need to test water tonight or just wait until the storm is over tomorrow evening. Not sure how much my numbers will be affected by all this rain.
    polyvue's Avatar
    Aug 2009
    1,215
    Sorry. This was in the TFP supporters forum, I've e-mailed it to you... check your Private Mail (PM)
    I plan to wait until the storm is over... but DID go out in the rain an hour ago to empty pump filter and skimmer baskets, pool cleaner bag and net the leaves, etc from the water. The pump filter basket is already full again and is cavitating somewhat, but I ain't gonna go out again until I'm dried off from my first foray into this storm.
    __
    Jan 2009
    Cupertino, CA
    1,966
    Yeah, I'm not looking forward to getting home tonight, having to go out in the downpour and start pumping to waste. Hope the cover hasn't floated away... or been blow away. And I just topped 'er off like, two weeks ago.
    --paulr
    BBB "Intermediate Swimmer"
