Results 1 to 9 of 9
Thread: Almost done... Leftover parts
    Still have to do tile and stucco. I simplified the design half-way through and ended up not using some parts (BBQ Galore access doors and a BBQ Galore side burner). I have them listed on ebay if anyone wants to get a good deal:
    BBQ Galore 20" x 14" Stainless Steel Access Door
    <ended>
    BBQ Galore 17" x 24" Stainless Steel Access Door
    <ended>
    BBQ Galore Side Burner
    <ended>
    [attachment=0:2spnbaqt]IMG_0250_small.jpg[/attachment:2spnbaqt]
    DrDave's Avatar
    May 2008
    Fallbrook, Ca
    154
    Re: Almost done... Leftover parts
    Fine job, why did you not use the other components?
    DrDave
    http://plansbyjorde.tripod.com
    Necessity is the Mother of Invention
    The project was taking me forever so I decided to just go with what I had done already so that I could finally enjoy a burger. This stuff is a lot harder than you guys make it look
    DrDave's Avatar
    May 2008
    Fallbrook, Ca
    154
    I hope you installed vents both high and low if you used propane. You did not show a photo of the back side.
    Why are you asking for $71.68 in shipping for the Turbo WOK unit on ebay?
    DrDave
    The UPS ground price is automatically calculated based on your zip code and the item's weight (almost 40 lbs). You must live pretty far from Tampa.
    Yeah, I have venting high and low. Here is a pic of the back.
    DrDave's Avatar
    May 2008
    Fallbrook, Ca
    154
    I didn't know ebay did that, sorry. Glad to see the vents. Good job.
    DrDave
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    That's one nice setup for... a hamburger! Hope you enjoyed it.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Yeah, easily the most expensive burger I've ever eaten. It was good though
    DrDave's Avatar
    May 2008
    Fallbrook, Ca
    154
    By the way, that is not a side burner you placed on EBay, it is much better. It is a Turbo WOK! I have had one for 10 years. You should really consider installing it. It is designed for WOK cooking, but can be used like a side burner and it will boil a lobster pot very fast. These are getting harder to find. If you were in So Cal, I would drive over and pick it up from you.
    DrDave
