Hi,
Can anyone tell me ( the pool chem guys), if I should be using the LSI for double checking if the pool water is corrosive or calcifying?
My colleague at work tested one of the pools I service at work ( kinda did that behind my back) and said" your too low on alkalinity and we just replaced the pool furnace!! If you keep that up ( low alkalinity), you'll wreck the furnace!
The Alkalinity happened to be in the mid 70's. He insisted it had to be 80 or higher.
I told him: " Don't you ever use the LSI to check for corrosive/ scaling in your water??" He said: "No! We don't have time to do that!!".
I told him I purposely keep the ALK in the mid 70's because the pH lands and stay's pretty much pegged on pH of 7.5 ( don't have to do the extra work with MA)
I told him i review each customers water when I get home and use Pentair's online LSI calculator ( tis quick)
For the pool in question the pH is 7.5; Alk 75 ish. CH: in the 280's ; more importantly the water Temp : in the mid 80's. So if i remember, the LSI is pretty much near 0.00
But more importantly, am I right for doing the extra step using the LSI - to further fine tune the water balance?
I know the alk should be 80~120, ch 250~350, pH 7.2~7.8
Should i ditch the LSI ? Especially if they're worried the furnace will corrode?
