Here are a set of new numbers from today:
pH ~7.5
FC 6.5
CC 0
TA 100 (using 10ml sample dilution method)
CH 350 (using 10ml sample dilution method)
CYA 60
water temp 75F
I added enough 6% bleach to raise FC to 8.5. Everything else is within range except for CYA. But overall numbers look good? Do I keep pH within normal recommended range now (instead of below normal)?
2nd questions is: going away for vacation for one wk. Any recommendations?
BTW, the acid odor was in the soil after it rained. It's much less now, but I have no idea what the source was.
Thank you.
pH ~7.5
FC 6.5
CC 0
CYA 60
water temp 75F
Thank you.
