Thread: Spa startup with BBB instead of BaquaSpa-Help?
    Jul 2009
    NorthEast
    40
    We have a softub. LOVE it... but hate BaquaSpa. We recently found out that the company decided you shouldnt use it indoors We have for years. Maybe it's why I now have Asthma??
    Hubby and DD BOTH came down with chickenpox/folliculitis looking rashes a couple of years ago when were tried chlorine before.
    I would like to try the BBB method in our spa. How do I get started?
    It is a 440 gal, 4 person Softub, vinyl liner, always been indoors and used indoors.
    Thanks for your help. We love it in the cold weather and would like to use it again. I miss our pool already
    **2009 installed 24'/52" AG Vinyl 25mil Printed Liner, 14,000 gallons
    1hp Pentair/Sta-Rite 150# Sand Filter hard plumbed w/timer, 31.5 GPM pump volume.
    'Lil Shark Automatic Vacuum. Addicted to our TF100 Kit :)
    **1995 installed 440 gallon Softub. Indoor use only. Previously used BaquaSpa. :( Would like to convert spa to BBB in 2017. ANY GUIDANCE WELCOMED!
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Spa startup with BBB instead of BaquaSpa-Help?
    Quote Originally Posted by resch
    Read the Introduction in this thread: How do I use Chlorine in my Spa (or pool)?
    There are instructions for converting a Baqua pool to chlorine in the Pool School, but with a hot tub you're much better off just starting with a complete change of water.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Jul 2009
    NorthEast
    40
    Can I use the TF-100 test kit we got (and love BTW) for our pool or do I need something else in order to test for the spa?
    It is stored right now so we would be starting out from scratch. I will read and post any other questions.
    Thanks so much!
    Jan 2009
    Cupertino, CA
    1,966
    Your TF100 will work equally well for the tub (mine does!). The target parameters might be a little different (typically want CH lower in a tub, ~100-150) but the testing mechanics are all the same.
    --paulr
    BBB "Intermediate Swimmer"
