Results 1 to 9 of 9
Thread: Gizmo bubbling
    Gizmo bubbling
    Hi,
    Blew out the line and trying to plug my skimmer but getting an air leak with the Gizmo. Using tape and a new Gizmo but no luck. Tried a plug but still bubbling. Any suggestions?
    Thanks.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Gizmo bubbling
    if a gizzmo with teflon tape bubbles, and a sp1022c plug with tape bubbles (unlikely unless not tightened [use can use a tool for extra leverage] or threads are damaged) then use a rubber plug, if a rubber plug still bubbles then use antifreeze in the line before installing the plug.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Gizmo bubbling
    Welcome to TFP!!
    Quick question - why the heck are you attempting to install a Gizzmo under pressure?? (if the water can't be lowered, there are other ways of taking care of the skimmer, including adding antifreeze, but a normal Gizzmo isn't part of it )
    Luv& Luk
    -Ted
    Re: Gizmo bubbling
    Quote Originally Posted by waste
    Welcome to TFP!!
    Thanks.
    I like this line of questioning as the skimmers have always been a pain in the you know at closing!
    Simply put this was the way I saw the pool company close my pool -they blew out main drain and skimmers simultaneously. Monkey See Monkey Do.
    Water can be lowered but Main Drain and skimmers are connected at the skimmer. Main Drain pressure is on the Gizzmo.
    Do you have a better technique for closing?
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Gizmo bubbling
    the gizzmo is not good for pressure, I would use a sp1022c if it is a 1 1/2 line, if not then use a rubber plug. Regardless you will need to use a tool to get proper torque on either plug to get a proper seal to be "air tight"
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Gizmo bubbling
    Welcome to TFP!!
    After we install a gizzmo or similar plug we splash a little water into the skimmer and then put air pressure using the blower to see if there are any air bubbles, if there are bubbles then we address the problem with a different plug etc. Regardless if it is air-tight it will be water-tight. We are so anal.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Re: Gizmo bubbling
    Thanks. I will try the sp1022c.
    Questions:
    1) How do I avoid over torquing the threads? Something like 1/4 turn past finger tight? They are plastic and I've stripped way to many threads already in this lifetime.
    2) What do you use to protect the skimmer from ice if no gizzmo is installed?
    Again, I appreciate the info.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Gizmo bubbling
    1. make sure to use teflon tape on the sp1022c, you can go pretty tight we actually use a ratchet with a custom blade on the end that fits into the slot of the sp1022c. If using a wingmaster tool to tighten I would go as tight as you can with one hand on the tool.
    2. we use a 1 gallon pool antifreeze bottle or windshield washer fluid bottle, they come with a gap of air at the top; add sand or stone to the bottle until the fluid is to the brim and reattach the cap. Now the bottle won't float in the skimmer and won't freeze so it can be squished by ice.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Sep 2007
    Toronto
    106
    Re: Gizmo bubbling
    There are actually 2 types of Gizmo, I use the one that has an opening and a plug on top and I have always installed it under pressure(ie. without lowering the water), water inside the pipes is blown out through the top hole of the Gizmo and I just place the plug on, job done.
    OH TWINS
    San Juan 8500 gal Fiberglass Pool, Sta-Rite Max-E 1 HP pump, Star-Rite System 3 Cartridge Filter 300 sq. ft,
    Sta-Rite Max-E 200,000 BTU gas heater, Aqua Logic SWG with P-4 panel. Goldline wireless remote control,
    3 Jandy Neverlube Valves with Goldline motorized control, iRobot Verro 500 pool cleaner
    5 Poolstar 1000 LED Lights, LED strip light at waterfall, Prozone Ozonator PZ7 with degasser column,
    Jandy Auto Waterfill, Aquamatic motorized pool cover, Poolbuster Max CC handheld vacuum.
