Page 4 of 7 FirstFirst 1234567 LastLast
Results 61 to 80 of 132
Thread: What does your pool paradise look like?
  1. Back To Top    #61
    In the Industry
    PoolguyinCT's Avatar
    Join Date
    Jul 2014
    Location
    Connecticut
    Posts
    2,594
    Re: What does your pool paradise look like?
    Quote Originally Posted by jimim View Post
    can I ask where u got the cushion n covers for the loungers. They r so expensive everywhere I check.
    During your build, I thought the raised design was going to be a goofy sore thumb..
    I was wrong, very slick backdrop.. I really like it & I seen 1000s of pools.
    Well done!!
  2. Back To Top    #62
    jza1736's Avatar
    Join Date
    Apr 2017
    Location
    Greenlawn, NY
    Posts
    497
    Thank you. It came out better than we imagined!
    Quote Originally Posted by PoolguyinCT View Post
    Well done!!
    17,000 gal 20' x 34' Polymer freeform pool, All Hayward products: Aqua plus 16v w/ SWG & Aqua connect, Summit 140k btu heat pump, Tristar VSP 1.85HP, 1 Universal Colorlogic light, 1 320 Colorlogic light, 1 4' lighted Sheer Descent, 2 Pentair Magic Bowls
  3. Back To Top    #63
    bmoreswim's Avatar
    Join Date
    Jul 2012
    Location
    Central MD
    Posts
    4,230
    Quote Originally Posted by jza1736 View Post
    I'm wondering from a design perspective if it has to do with the length of the raised area. It is relatively long in relation to the pool which seems to be the difference between ones I like more and ones I like less. Makes it seem more substantial and heavy, grounding the pool.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
  4. Back To Top    #64
    Join Date
    Mar 2016
    Location
    McKinney, TX
    Posts
    179
    Quote Originally Posted by bmoreswim View Post
    I agree! it looks amazing!!
    17K gallon, 18x40, 107 perimeter, 550 sq ft gunite inground pool with raised spa. 3.5 ft. - 5.0 ft. - 4.0 ft depth. Pentair equipment. DE filter. English Walnut travertine paver decking, lueders limestone coping. Wet Edge Primera Stone Sapphire Treasure plaster.
  5. Back To Top    #65
    Arizonarob's Avatar
    Join Date
    Mar 2018
    Location
    Chandler Arizona
    Posts
    1,017
    Yeah, I think you nailed that one. The wall being as long as it is def made all the difference. If it were shorter, it would have looked like an afterthought.
    The water bowls on the ends really tie it all together nicely.
    ~Rob
    11,000 gallon in ground plaster pebbletech finish. Hayward Tristar VS, Hayward Swimclear, and Hayward Aquanaut 200 pool vac, K-2006 Kit, Speedstir.
    FC/CYA Chart-Finding a suction side air leak>https://youtu.be/eweIDTnJCUw
  6. Back To Top    #66
    Join Date
    Aug 2016
    Location
    philippines
    Posts
    9
    Well this is a rental house with pool. So i didnt build. But to answer your main question,i think its harder to keep clean.No leaks in the grout,but seams to be where the alge likes to cling to. But that could be that im not a seasoned veteran in maintaining pool water balance. But im learning quickly.
  7. Back To Top    #67
    jza1736's Avatar
    Join Date
    Apr 2017
    Location
    Greenlawn, NY
    Posts
    497
    Quote Originally Posted by Arizonarob View Post
    The funny thing is the PBs Mason didn't know how to use a Tape measure and it worked out in our favor. We wanted to the wall to be 28' x 18" w/ 24" piers. They built it 32' x 21" w/ 28" piers.
  8. Back To Top    #68
    bmoreswim's Avatar
    Join Date
    Jul 2012
    Location
    Central MD
    Posts
    4,230
    You must have some good karma!
  9. Back To Top    #69
    jza1736's Avatar
    Join Date
    Apr 2017
    Location
    Greenlawn, NY
    Posts
    497
  10. Back To Top    #70
    Join Date
    Aug 2018
    Location
    St Louis, MO
    Posts
    1
    Beautiful tile work! What are the dimensions of your pool? And, the dimensions of the shelf? Thanks in advance!
    Quote Originally Posted by Flying Tivo View Post
  11. Back To Top    #71
    Join Date
    Jul 2016
    Location
    Long island,NY
    Posts
    52
  12. Back To Top    #72
    Arizonarob's Avatar
    Join Date
    Mar 2018
    Location
    Chandler Arizona
    Posts
    1,017
    I think that pool float has sinister thoughts. I’d watch him closely.
    ~Rob
  13. Back To Top    #73
    Join Date
    Jul 2016
    Location
    Long island,NY
    Posts
    52
    Ha! Iíll have to keep a close eye on my CYA...
  14. Back To Top    #74
    ctrav's Avatar
    Join Date
    Apr 2017
    Location
    Northlake TX
    Posts
    2,348
    :j
    Cliff, IG, 22K gal, Pentair WF 2HP 2 Speed Pump, Pentair FNS Plus 60 DE Filter, Hayward PL Plus Pool Management, SWG T Cell-15, 2 LED Hayward Color Logic 4.0 Lights, Water Features, Diamond Brite Black Onyx pool finish, TF-100 Test Kit, PoolMath App, Dolphin S200 Robot (Phin). Northlake, TX New Pool Build
    I support TFP Forums ♥ Has the info saved you $? You can support too!
  15. Back To Top    #75
    cwescapexlt4x4's Avatar
    Join Date
    Jul 2014
    Location
    Litchfield Park, AZ (PHX metro area)
    Posts
    483
    Part of the backyard and shade sails from Costco... They've been up since June, thru many monsoon storms and working great!
    Chris - aka cwescapexlt4x4
    (Build 8/26/14 - 10/17/14) in-ground Presidential Pools 15K gallon salt water pool Pentair Inteiliflo pump, Regal Blue Pebble, Clean & Clear filter, in-floor cleaning,
    LED light, 3' sheer spill, 2 benches, large Baja step. / Pergola by Booth Built 19W x 14D // Outdoor Kitchen, W/Primo grill and BBQ Coach kit for the island.
  16. Back To Top    #76
    Arizonarob's Avatar
    Join Date
    Mar 2018
    Location
    Chandler Arizona
    Posts
    1,017
    Chris, you need to hit up moon valley nursery and get some tall shrubs to block those neighbors windows!!
    ~Rob
  17. Back To Top    #77
    Join Date
    Jul 2014
    Location
    Posts
    483
    Yeah, we are adding more as they are a PITA neighbor....
  18. Back To Top    #78
    birdieboy's Avatar
    Join Date
    Aug 2018
    Location
    Far Hills, NJ
    Posts
    13
    Here is our beauty...
    23,500 gallon in-ground plaster aggregate and raised spa waterfall, control system with remote, single speed 2hp pump, 48 square foot DE filter, heat-pump, booster-pump, 3-wheel pressure-side pool cleaner, chlorine sanitizer, mineral and tri-chlor alternative sanitizer, LaMotte DPD Test Kit, TFP PoolMath, private well water, 2013 Spring build.
  19. Back To Top    #79
    ctrav's Avatar
    Join Date
    Apr 2017
    Location
    Northlake TX
    Posts
    2,348
    Awesome shady!
  20. Back To Top    #80
    Join Date
    Dec 2015
    Location
    Newport Beach, CA
    Posts
    80
    20180828_142047.jpgHere's a better pic of my pool paradise. Wouldn't be paradise without the unicorn
    Approx. 13,500 gallons above ground
    All glass tile
    Hayward DE Filter, Hayward VS Pump- (pool filter), Hayward VS Pump (neg edge overflow)
    Date of pool build: 2018
    Spa, Ozone UV, Autochlorination, AutoPH, Autofill, Omnilogic, Taylor K-2006
Posting Permissions
  • You may not post replies
  • You may not edit your posts
