Results 1 to 7 of 7
Thread: Slippery steps
    Mar 2007
    Knippa, Texas
    289
    Slippery steps
    The steps in my fiberglass pool are very slippery. The previous owners stuck some bathtub stickers on the edge of the pool which does help the traction there. Seems like a good idea, but not helpful for underwater.
    I need to put in handrails, which may be the only helpful addition possible w/o draining the pool. Does anyone know of a way to provide some traction on those steps W/O draining??
    ~Jules~
    My pool: INDOOR 13x27 rectangular fiberglass, built ~2001, BBB, TA-60 sand filter, Hayward two speed pump (1 hp/0.33 hp), 3/4 hp booster pump for solar heater
    Taylor K-2006 test
    Someone previously suggested surfboard traction tape.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Good idea. We use that on the pvc shower perches we make for parrots. Great grip. The steps need to be clean (no oily spots, dirt) and dry when applying or you will have areas lifting.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    New Brunswick Canada
    819
    A suggestion is to apply this during spring opening, lower water to get the steps dry, then apply, it works wonders.
    New Jersey
    98
    suction cup bath mat
    I had the same thing. I went to walmart and purchased a clear bath mat with little bumps all over it and suction cups on the bottom. We feel its a big improvement on grip and seems to be staying put very well. Its been in the water 3 weeks and all is well. It cost me $5 and I cut it into three pieces for the steps. I can take a picture if that helps. Let me know.
    Ls
    14 x 32 Fiberglass Pool 10K gal. Hayward Pump and Sand Filter. Autopilot SWG Dig 48 and Heat Siphon 3.25sx Heat Pump.
    The Pool Calculator
    Chlorine/CYA Chart by Chemgeek
    Mar 2007
    Knippa, Texas
    289
    Quote Originally Posted by pooladdict
    I don't close my pool.
    Sounds like the bathmat would be my best bet!
    Thanks all.
    ~Jules~
    Taylor K-2006 test
    819
    I am sure you could apply this with water up with that vinyl repair glue?
