Results 1 to 8 of 8
Thread: Outdoor Speakers, Speaker Wire & Distance
    WaterWoman's Avatar
    May 2008
    Sacramento, CA area
    139
    Hey there!
    I have a question about running speaker wire to some speakers for use on the patio, and am hoping someone here might know something about this. We have some outdoor speakers that came with the house that can be put up under the eaves, but I've never tried them, so don't even know what they sound like. I may try them out, and if I don't like them, get something better to replace them. They'll only be outdoors in the summer, and it doesn't rain here in the summer, so weather isn't a problem. But that's really beside the point of my question.
    We're having a Halloween party next month and, weather permitting, I'd like to have some outdoor sound. The pool will be too cold to swim in, but it won't be too cold to have a fire in the fire pit nearby and some dancing on the patio.
    What I'd like to do is run speaker wire from the stereo system in the living room out to the patio. I have connections for a second set of speakers (A & B, can use either, or both), and it would make more sense for CDs and other equipment to stay indoors. But how feasible would it be to run speaker wire for a distance of 30 to 50 feet? What size wire would be best to use for such a distance? Or would I lose so much signal that it wouldn't be worth it? Any thoughts? Ideas? Suggestions?
    Thanks!
    20,000 gallon in-ground gunite ~ sand filter (62 gpm) w/Vari-Flo valve (75 gpm) ~ 1.0 HP dual-speed pump
    Guest
    Re: Outdoor Speakers, Speaker Wire & Distance
    Should be no problem. Get the largest size wire you can get (gauge) and you will be fine. My run is farther, and my situation sounds very similar (speaker outputs. I use my iPod or iPhone and put it on shuffle).
    Party on
    Bruce
    WaterWoman's Avatar
    May 2008
    Sacramento, CA area
    139
    Cool! Thanks, Bruce!
    Jan 2009
    NC
    49
    I ran 12 gauge ul Wall rated speaker wire about 50 feet, I installed 4 out door speakers (2 rocks and 2 under the over hang on my roof) they all sound great. I put them on Zone 2 of my receiver, with a speaker selector. So I can have someone inside watching a movie in surround sound, and play music outside, All on one receiver, its great.
    Also Make both wires equal. Meaning Run your longest wire, Then make all your runs, that lenth. Makes the sound much more even.
    John
    15x30 inground vinyl pool. 1 hp hayward pump, 200 pound sand filter. 8 feet deep in the deepest part. 3 feet in the shallow. 4 returns 2 in the steps, 1 in the shallow end, and one in the deep, 1 skimmer (wish there were 2) and one Main drain. Only thing I wish is I had a more powerful pump, The jets never really put out alot of power. No frills pool. Has a light and thats about it as far as specail features go. BBB user ever since I opened this season thanks to TPF
    Mar 2007
    Ontario
    211
    I have been using the brown thermostat wire for 4 years with no problems. The one run is about 60ft and buried. I remember it was not that exspensive for a roll a of 100'.
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    WaterWoman's Avatar
    May 2008
    Sacramento, CA area
    139
    Thanks, John and haybird! Appreciate the advice!
    Jun 2007
    New Jersey
    653
    I feed four remote speakers from the Zone B output of my Living Room Denon stereo amp through a Parasound 4-output speaker switcher. I bought a 500' roll of 12-gauge speaker wire from a local electronic supply house. The longest run is to the pool, through a separate conduit in the same trench with the electric, about 140' , where I have a pair of outdoor Paradigm speakers. There are tables as to gauge, wattage and distance, but 12-gauge is best for almost anything. I wouldn't use 14-gauge for anything more than a small speaker in the same room as the amp.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Jul 2008
    Clovis,Ca
    54
    When I wired my sound system from my outdoor kitchen, I used 12ga low voltage light wire from Lowes, from a tip I read on here.
    It is direct burial, so no need for conduit. One lead is also marked with printing, so keeping "+" and "-" seperate is easy. Much cheaper (price wise) than a dedicated "outddor speaker wire".
    My runs are about 50 ft from the receiver, and it sounds great!!! FWIW.
    C-Ya!!
