I've owned my home with pool for 10 years now. It seems that the longer I'm here the less life I get out of my cartridge filters. Lately, if I buy a new cartridge, it lasts me about 2 years before I'm forced to replace. I get high pressure and low flow near the beginning of summer. I pull it apart and thoroughly spray all of the debris out with a hose. Pressure is good after this for half a day & then back up again. I've soaked the cartridge numerous times in both the Leslie's cartridge cleaner solution as well as a home-made powder Cascade concoction. Either of those cleanings work wonders for about 6-24 hours and then I'm back to the same issue. After thorough cleaning I'm around 11 PSI & then once I hit 20+ PSI the slide stops working and jets are low pressure.
Is there something I'm doing wrong that could be contributing to my cartridges clogging. Is it possible that there is some kind of alien pollen in the air of Oklahoma that does this?! I believe I should be getting several more years out of these cartridges. My filter is an older model Jandy so it's one giant cartridge that costs like ~$200 to replace. Not exactly cheap.
I purchased the K-2006C test kit about 3 weeks ago. I've been faithfully testing my water every couple days & adjusting chemicals as needed. Prior to that, I always relied on local pool stores for testing. Here are my readings as of today. Water has been crystal clear for a while.
PH - 7.4
Alk - 90
Calc H - 190
Cyn Acid - 20
FC - 2.4
CC - .2
I'm in the process of adding Cyn Acid via a stocking in the skimmer so I expect that number to go up over the next week. I will also be adding a bag of salt too. I really appreciate any advice! This forum has been a great help to me over the years just by reading other's experiences. Thanks in advance.
PH - 7.4
Alk - 90
Calc H - 190
Cyn Acid - 20
FC - 2.4
CC - .2
