Thread: What can I use to removed small tar spot from liner?
    flyboy320's Avatar
    Jul 2009
    Burlington, Ontario, Canada
    216
    I just had my roof redone, and despite my best efforts to keep the pool covered, there are a few (maybe a dozen or so) small (size of a pin head) what seem to be tar spots. They are all at the water line, and when I rub them with my finger they smudge. Is there anything that's good/safe to use on vinyl liners to remove something like this? I have stuff called "GOO GONE", but it says not to use on such things a leather, and rubber....
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: What can I use to removed small tar spot from liner?
    they sell vinyl cleaner at pool stores, I personally use wipe-out. If all else fails you may want to try a mr. clean magic eraser but please be warned I have seen them remove the ink from older liners.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
