Thread: running filter till we close
    Taking everyone's advice about leaving the pool open later than we usually do till water temp drops, etc. We'd normally close this weekend. During the swim season, I'd run the filter 10-12 hours/day. Hate to run it that long when no on is swimming, but how low can I go and still have it filter effectively?
    Off subject, but someone explained once how to add the pool info so it 'sticks' each time I post. Thought I had it, but guess i messed up somewhere! Can anyone chime in with the directions again as to how to add that info? Thanks. Btw, for the above question, we have an AG, 22, 000 gal..using BBB.
    22,500 gal A.G., vinyl, sta rite crystal sand filter- Pentair Water Pool & Spa , Hayward Super Pump Self Priming 10" lift, BBB method
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: running filter till we close
    To add a sig, go to User Control Panel link (top left, under the TFP logo), click on Profile, click on Edit Signature, enter your info and submit. Please keep it to 5 lines or less, per forum rules.
    Pump run time will depend on the flow rate of the pump and head loss of your plumbing. Head loss should be negligible for an AGP, so if you know the flow rate of your pump in gph, divide the size of your pool by that number, and that'll tell you how many hours to do 1 turnover of your water. IIRC, you generally want two turnovers a day for good filtration, so multiply that number by two.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Will I find the flow rate written somewhere in the pump manual? And I assume you mean dividing that number by the number of gallons when you say pool size, correct?
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    The pump manual and/or the pump mfr website should have a loss curve for that pump which shows the flow rate vs head loss, and you have to figure up your head loss and use that curve, unfortunately. Who's the manufacturer of your pump?
    Yep, I meant the volume of the pool divided by the flow rate of the pump.
    How did you come up with the pump run time you have now? Just a guesstimate and it worked OK?
    Intex 8110 SWCG
    "Fear the Schnauz!"
    OK, here's what I think we have. Waterford systems high rate sand filter systems..model jsal 210 series. 21" filter (we got this number by measuring the tank diameter and find the comparison in the manual)
    So....according to the chart in the manual, it gave us a Flow rate max = 43.6 gpm. so dividing that by 22, 500 gal gave us 8 hours for 1 turn over. That would mean we'd need to run it 16 hours??? Does anyone even run it that much during prime season?? Something's not right! Help!
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    We have a 12.5K gal AGP with a 2-speed Pentair pump and a Hayward sand filter.
    We run the pump for 6 hours on the low setting during the night and for 2 hours after we've been in the pool during the day. I have no idea what its flow rate is but the 6 hours every 24 have worked fo us for five years now. I set it on high when I vacuum.
    Now that the pool is used less I've set it back to run 4 hours during the night. I still do add chlorine every 3 days or so and when I do, I mix it in manually by shoving the brush around some.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
