Adding CYA, adjust pH or wait?
Aerate your pool to raise PH. You can do that while your CYA dissolves.
I assume it will drop more by the time I am done.
Curious, why? Do you know what is causing your pH to fall so much when usually pH will rise on its own? Are you using something acidic (i.e. pucks), did you overshoot with muriatic acid, or is your TA exceptionally low?
No baking soda. Your TA is fine. Just a little borax to raise the pH to about 7.2-7.4 for now. Then let the water go for a day or two and re-test as pH tends to rise on its own. At the same time, increase your FC right away. It's too low as noted on the [FC/CYA][/FC/CYA].
I'd wait. Once the granules are all dissolved, then check in a day or two. You're at 40 now, it may climb a little more. So watch the FC level to ensure you are keeping-up with the CYA to keep them balanced as noted on the [FC/CYA][/FC/CYA].
