Thread: Sta-rite spa heater 'calibration'
    I had a spa heater replaced today and the factory setting is 104ΒΊ. The old heater had been 'calibrated' so that it would make it to 108ΒΊ. But, I forget how I did it. Anybody know?
    Sta-rite Max-E-Therm 200LP
    First-timer Felix
    1) 15000 Gallons
    2) Sand
    3) In Ground
    4) Gunite
    5) Hayward Northstar 2HP
    6) SWG
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Sta-rite spa heater 'calibration'
    Hi Felix welcome to TFP!!
    NO heater sold in the US should be able to go over 104*!
    104 is the max temp they allow
    I wouldn't worry about the extra 4 degrees
    Luv& Luk
    -Ted
    Guest
    Yup, somebody fiddled with the old heater to make it do that (bad pool guy!).
    Unless your making broth, you will be just fine at 104!
    Bruce
    The guy whose spa it is wanted the old one that way...and, wants the new one that way. I never get in the thing. And, I was the one that changed it...I just forget how I did it (was talked through it by the original, now gone, installer) I think 104 is too hot!!!
    1) 15000 Gallons
    2) Sand
    3) In Ground
    4) Gunite
    6) SWG
    Guest
    Quote Originally Posted by Felix
    Oops !
    Bruce
    No fret! I didn't want to do it. But, when the bossman says 'make it hotter', I say "How high?"
    1) 15000 Gallons
    2) Sand
    3) In Ground
    4) Gunite
    6) SWG
