Thread: Just bought a house in Phoenix, some questions.
    Apr 2009
    Phoenix, AZ
    3
    I just bought a house in Phoenix and have some questions regarding the pool. They previous house I lived in was a rental and had a pool. So I'm familiar with the upkeep of the pool. But the pool in the new house is different.
    Apparently it's a lagoon style pool. The weird thing is that there is no skimmer like the last pool. The vacuum hose for the new pool just plugs into a water intake inside the pool all the wall. And there is a clean out basket over by the pump. But there is no skimmer with a skimmer basket or anything. So I can't just run a skimmer to get the fine particles of debris off the surface of the water. Is this normal?
    My other question is: the in take for the vacuum hose under the water has a closing flapper type of thing on hinges that closes the hole when the hose isn't plugged into it. If I remove the hose and turn on the filter/pump (so the waterfall and sprinkler run) will it damage the system. It appears to work with the flap closed because water does come out of the waterfall and sprinkler. This in take valve thing appears to be the only place where water is pumped from the pool and through the filter system.
    Can anybody provide some insight?
    Thanks.
    My Pool - 21,000 Gallon Plaster In Ground Manatee Shaped Diving Pool - Sta-Rite Dura-Glas Pump 1 1/2 hp, 3450RPM, 48Y Frame, 230/115 Volts, 60hz., 9.6/19.2 amps - 24" Jacuzzi Bros Sand Filter 60 GPM (46 Backwash)
    Guest
    Re: Just bought a house in Phoenix, some questions.
    Any main drains in the floor of the pool or wall penetrations with covers?
    There is only a limited amount of water that a wall fitting for the pool vac can take in, and I would assume (hope!) that there are other intake sources that you have not seen yet.
    Weird about no skimmer, but stuff happens....
    Bruce
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Is this an in-ground or above ground pool? Plaster/marcite or vinyl liner, etc? Any pictures you have might help with understanding the overall plumbing scheme.
    Welcome to TFP...
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Apr 2009
    Phoenix, AZ
    3
    There is a main drain on the floor of the pool. It's an in ground pool.
    I'll take pics tonight and post them.
    Thanks.
    Guest
    So the lack of a skimmer would say that the pool pump is sucking from the main drain and the vac line, with a 3 way valve allowing control of suction between the two.
    Maybe the back yard gets little surface debris and the previous H/O decided against a skimmer and used a leaf bag for whatever little surface debris got in the pool. That way he/she didn't have to see an ugly (!) skimmer in the deck or worry about it down the line. I'll bet the surrounding area looks nice and uniform without it
    There really is no rule that you have to have a skimmer, although it is the norm (think of alot of vanishing edge pools; there are often no skimmers on them as the edge is the skimmer!).
    Congrats on the new place
    Bruce
    Apr 2009
    Phoenix, AZ
    3
    I decided to call the pool service guy who used to take care of the pool for the previous owners. He's going to come out and explain the whole setup for me.
