Thread: Using the Pool Calc to determine x gal
    rdkll's Avatar
    Jul 2007
    Huntsville, AL
    41
    I put bleach in the other day to bring clourine to 15ppm, an hour later it 3as 13.5 ppm, and it stayed there for 3 retests(taking samples from same spot, thanks Duraleigh)
    I dont remeber what I was bringing it to 15 ppm from.
    Before I get started again, I dont think I shocked long enough (got sloppy on my overnight drop) I am ready to do the hourly battle, but would be cool to have an exact formula for my pool.
    As always, Thanks In Advance
    1) The size of your pool in gallons = 33,500 16x32x40 L
    2) The type filter you have = 300lb Sand
    3) IG
    4) If it's IG, vinyl liner
    5) pump is 1.5hp
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Using the Pool Calc to determine x gal
    Quote Originally Posted by rdkll
    Fortunately, shocking isn't rocket science but it pays to do it right the first time!
    May I suggest that you...
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
