Thread: Pump is slingin' water
    Mar 2008
    Central VA
    328
    Hey everyone, sorry I haven't been on here in awhile...busy summer for sure.
    The GOOD news is that I truly have had a 'Trouble Free' summer, thanks to changing to the BBB method and SWG last season, helped along by you great folks.
    Now for the only trouble I've had, my pump...
    My Pentair pump has been reluctant to restart anytime I've stopped it this summer. I've had to take it apart and spin the impeller, then re-assemble it, to get it started on most occassions.
    Today I noticed that the pump is now leaking (really, 'slinging') water out of the motor end. It's also got some salt buildup where the motor side meets the filter basket side. It's not leaking from the gaskets as far as I can tell; it's actually 'slingin' water from the motor side.
    So is it a goner? Or can I squeeze a couple more weeks out of it?
    thanks for any help!
    Todd
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    http://www.poolcalculator.com/
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Pump is slingin' water
    Todd, sounds like the shaft seal assembly went bad on you
    It's a pretty easy fix and not too expensive. There are a few posts here on changing one (including one in the 'further reading' section of Pool School.
    If you need any help with it - we'll be here for you
    Luv& Luk
    -Ted
    Mar 2008
    Central VA
    328
    Thanks!
    Todd
