Results 1 to 7 of 7
Thread: Closing pool for first time since our conversion
    This is the first time we will be closing down our pool since our conversion. I have read pool schools method for closing down an above ground pool.
    It is my understanding that I will need to shock the pool and make sure the level holds over night? then continue with the closing procedure.
    My question is can I use teh baquacil algacide? I still have several bottles left from our conversion? If so how much a whole bottle?
    Also I am assuming I can add it after I shock the pool, like the next day and then let is circulate a while before I drain the pool down?
    21ft round, 54 inch deep DoughBoy Desert Spring Above ground
    3/4 HP Dough Boy pump, Sand Filter
    Knoxville, TN
    GO VOLS
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Closing pool for first time since our conversion
    What is the active ingredient?
    The active ingredient in the Baquacil Algicide is n-Alkyl 60% adn dimethyl benzyl ammonium chloride 49.8%
    I hope that makes sense?
    We used it last year when we closed down but we were on the entire baquacil products...just need to know if this will work for closing down since we converted? if not then what do I need to buy?
    and how much ?
    Knoxville, TN
    GO VOLS
    Ok so after some research I am pretty sure the baqua algaecide isn't a polyquat? Please let me know?
    I am sending my husband to the pool store tomorrow what strength do I need and is there a name brand I can give him that he can just ask for?
    I am assuming he can just look at the label to verify that is is a polyquat? I hate going to the pool store b/c they always have some smart comment and item to sell us? Just need to get the correct stuff and get out of their quickly?
    Knoxville, TN
    GO VOLS
    Butterfly's Avatar
    South Carolina
    10,045
    I don't know the name brands, but it should say "Poly[oxyethylene(dimethyliminio)ethylene(dimethyliminio)ethylene dichloride] 60%" as the Active Ingredient.
    If it says "Poly" and "60" in the name, that is most likely the correct product.
    You're done SLAMing when:
    Mar 2007
    Coastalish 'down easter'
    4,160
    Hi, while I may not be chemgeek, I'm pretty sure that what you have is a linear quat
    The good news is that it will still prevent algae growth The poly is better in a few ways, but the linear stuff you have will do the job - the economy SUCKS and why spend more $$ when you have something you can use? Have you converted from Baq yet? If not, I would use their algaecide while still using their chems
    I don't mind using the stuff you have unless! you have a SWCG - if you have over ~ 1500 ppm salt in the pool, the linear quat will cause a 'sheet' of foam on the pool surface
    Good luck with the closing and I hope to see you around over the winter, and if not over the winter - I expect to see pics of your pool next spring and hear how easy it was to open
    Luv& Luk
    -Ted
    we have converted to chlorine via the bbb method! our pool has been fab! So I CAN use the baquacil algaecide? since i have 3 bottles left from our conversion?
    Does anyone else agree?
    what is the consequences pro/cons or using the baquacil instead of the polyquat? I don't wont to cheap out and cause any major problems over the winter or algae?
    Knoxville, TN
    GO VOLS
