Thread: Help with Sta-Rite heater and Aqua Logic
    Sep 2009
    Madison, AL (north AL)
    77
    Hey, first post (new pool). I've got an Aqua Logic PS-8 and a Sta-Rite SR400NA heater. I'd like to control the temp with the thermostat setting in the AL menus, but the heater itself has its own thermostat setting on its control pad. They seem to conflict with one another. If I turn the heater thermostat all the way up, will this allow the AL to be in control?
    BTW, the AL is connected to the heater with the 2-wire config using the Fireman's Switch.
    Phillip
    25k gal IG freeform pool, gunite/plaster, built in 2006; Aqua Logic AQL-PS-8 control w/ T-CELL-15 SWG; Sta-Rite S8M150 cartridge filter; Sta-Rite SR400NA gas heater; Polaris 280
    Jun 2007
    SF Bay Area
    441
    Re: Help with Sta-Rite heater and Aqua Logic
    PhilipH,
    Welcome to BABC!
    I have an Aqua Logic PS-4, so it is virtually identical to your unit. I don't have the manual right in front of me, but from memory the heater temp controls should be set as high as they can possibly go. That way, as far as the heater itself is concerned, it is always ready to go on whenever the filter pump is turned on. Then the Aqua Logic decides, based on the water temperature sensor input, when the heater should turn on and off via the Fireman Switch connection.
    I hope this helps. If not, keep asking questions.
    Do you have the Aqua Logic manual?
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    Sep 2009
    77
    Thanks. I do have the manual, and the most relevant info is in the Installation manual (not the Operations). Looking at the connections for the "generic" heater is what tipped me off. It says to do just what we are saying regarding the heater temp. However, I have a Sta-Rite heater and the AL manual has a special section for a Sta-Rite heater, and it doesn't mention anything about turning the heater temp up. I bet that's it though, and I'll verify in the next couple of days.
    Phillip
    Mar 2007
    Coastalish 'down easter'
    4,160
    Phillip, Hi Titanium gave you the 100% correct answer (Hi Titanium, boy... it's great to share a thread with you again! :P )
    Just to reiterate, set the heater to it's highest temp and then let the AquaLogic take over --- as long as you have the water temp probe installed!!
    Luv& Luk
    -Ted
    Jun 2007
    SF Bay Area
    441
    waste,
    I'm honored that you remembered me.
    I haven't been very active this summer on the board.
    Sep 2009
    77
    Quote Originally Posted by waste
    Yep, that did seem to work last night. Thanks guys.
    Phillip
