I somehow trust the OP, he seems to be skilled and know what he's doing. He's on the right track in troubleshooting the transformer.
hmmm....I'll take this back. I have reasons to believed, my troubleshooting skills over the internet is doomed to fail.
You're right, I checked DC on the yellow.
Sorry, I didn't see this coming and wasn't expecting at all from you.
Yellow to Yellow is 24VAC. Orange to ground lug shows proper voltage.
...this is broad and more complex! But what is the proper voltage?
So I now checks red and black wires according to the troubleshooter and it shows no VDC (should be 18-33 VDC). So this takes me back to the rectifiers. I only have one so maybe they are both bad and I'm not testing them properly somehow. So I guess I buy 2 rectifiers??
I can only assume you set the Voltmeter to measure DC voltage to probe the Red and Black wires. The Voltage across the Red and Black wires when connected to a functional PCB is a mirror of the Voltage reading on the Display under Diagnostic. This is true, regardless of the system AC power input configuration.
The yellow 20A fuse, link the orange and one of yellow wires from the Transformer.
Tips for you... before you shotgun the Rectifiers!
1. disconnect the red and black wires from the PCB.
2. set the Voltmeter to measure DC
3. turn on the AC power and probe across the red and black wires. If the rectifiers are good, you should read 23-24V DC. If false, inspect the fuse. By design, the Fuse should blow if one of the rectifier went bad!
Just make sure to replace the rectifiers with the same type number and take note of the polarity. Take pictures before pulling any wires.
