Results 1 to 8 of 8
Thread: Helping a friend with above ground pool-How 2 water drainage
    A friend of mine is trying to build a deck around this pool...but we must first address the water drainage issue around the pool, I have an in ground, so i really don't know what to do, can anyone help???? You can see that there is a gag between the pool to the ground of about 12"....
    DIY Fiberglass Pool under construction
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Helping a friend with above ground pool-How 2 water drainage
    I would try back filling around the pool with some dirt and walk on it to try to tamp it down as hard as you can. Then I would think about watering it and letting it settle for a day or so then put more dirt on the top and do the same thing again. After you are done I would put some pea gravel or 57 stone over the dirt to try to stop it running off .....
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    so...there is no necessity to build a drainage...just back filled?, what happens when it rains? and the water zips in....???
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    I dont think so ......
    How deep is the gap?
    Les
    Helpful Links:
    some places are almost 24" while other 12"
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    I personally think if you back fill the gap with dirt and compact it to help it settle you should not have any problems with it.
    Les
    Helpful Links:
    Jul 2008
    Solon, Iowa
    170
    It depends upon how high you want backfill against the pool wall. My install left me with 3 feet banks around much of the pool. I didn't want that much wet soil lying against my pool wall, so I decided to widen my trench, retain the dirt with timbers, and grade the trench to drain to one end where it could exit with the surrounding terrain. I then topped with a few inches of river rock to prevent washing out. Works well and I sleep well during the wet winter/spring, not worring about standing water and a sinking pool. You don't need the timbers, but you could grade the trench so you don't have a bowl, make sure one end drains to the natural slope, and backfill with rock.
    15X30 AGP, Lomart beaded liner;
    1.5 HP Sta-Rite pump with 21 inch sand filter (Zeobrite media)
    Mineral Springs (Aquatrol) SWCG, Rigid PVC plumbing, 2 inch
    Four 4X12 Techno-Solis solar panels, rack mounted, Goldline Solar Controller
    We used white rock around ours. One side was about 4 inches, the other about 8.
    18 X 54 Round-Wilbar-Sharkline Above Ground Tahitian
    Stainless steel access panel/ 1.5 hp pump
    Self Installed 6/09
    Crushed by Irene, and a 50ft oak 8/28/11
    Re installing 4/12 and up and running
