Thanks, Kerry. Will definitely get that gasket and top assembly replaced this week based on your experience. Just need to pick up some glue for that gasket. Mine is leaking anyway, so it needs to be replaced. Will post again after doing that repair and running the filter for a few days and let you know if the pool is any clearer. You always turn the handle on a multi-port valve in the same direction, right? I assume it doesn't matter which was you go as long as you always turn it in the same direction. Thanks again.
