Hi all been parsing your forum for days now. Lots of helpful,useful information.
I cannot for the life of me find the cause of my issue.
A little history to help out. Bought a house have a pool now. This was a year and a half ago. Pool system is a 18,000 gallon inground plaster pool. Hayward 1.5hp maxflo xl pump. 1.5inch suction line to pump. 1.25inch return line to 3 jets.
No valves before pump. Built in 1976 by Pools by Anthony. Original filter up to 3 days ago was a Sta Rite system 3 S8-500M.
That filter was made for people with cash growing on trees. 3 days ago i got my Pentair Clean and Clear 200 RP. Got it mounted down and plumbed in. Now my problems arise. I had never noticed air bubbles in the strainer basket till now. Old filter had an automatic air bleed system. Never saw air out the return jets either.
I have replaced the strainer basket o ring, lubed and reset every union before and after the pump and filter. Followed every single advice i have found here and on the web. It rained last night for a good 30 minutes. I had the pump running, the air bubbles were GONE. I have done the water trickle over the pump and fittings test MANY times and never got this result. I had also filled the pool to within an inch if the top of the skimmer inlet. After the rain the pool was over the entrance to the skimmer. The small vortices were gone as well. I thought ok it was just not enough water. Went to bed, let the system run its timed schedule. This morning strainer was low on water after pump shut off. I manually restart pump to prime it and the darn air bubbles streaming in are back. Water level in pool is high. I let the air out of filter, And shut it off. What am i missing here.
Thankyou for any and all help,
William
William
