Results 1 to 10 of 10
Thread: Possible algae?
    Apr 2017
    Lake Charles, La
    15
    Possible algae?
    We opened our pool a week ago and after refill, stabilizing, and chlorinating (SLAM levels) the water is a beautiful, cold dream. Except for this issue (photo attached if I did that from cell right).
    Here are my numbers:
    FC 12
    CC 0
    PH 7.4
    CYA around 28 (was 30 but we've done vacuuming to waste)
    TA 200 (but ph doesnt rise much)
    We only get this stuff on the bottom while the sand filter is running. After I brush or vacuum, it just dissipates or it comes right back thru the filter. When the pump turns on there is about 2 seconds of a light brown "something" that flows thru. After several hours all of the stuff in the photo settles.
    I did an OCLT test and we lost no chlorine. Is this possibly algae, do I need to SLAM more? I'm at my wits end.
    Location: Southwest Louisiana. 22' Round Intex AG pool. Sand filter. Test kit: Taylor K 2006.
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    1,128
    Re: Possible algae?
    Have you backwashed your filter lately?
    16' by 4' Intex Ultra Frame AGP
    Intex 120V Krystal Clear Sand Filter Pump & Saltwater System CG-28679 with E.C.O.
    Hayward Through Wall Skimmer, Intex Auto Cleaner - works great!
    TF100 Kit and Speedstir
    Get the Pool School ebook, free on Google Play!
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    470
    Re: Possible algae?
    If you passed the OCLT, my guess is that it's dust. I have trouble with fine dust getting through my sand filter too.
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    Apr 2017
    Lake Charles, La
    15
    Re: Possible algae?
    Quote Originally Posted by kellyfair View Post
    We have 2x after we got the pool clear, and numerous times last week after each vacuum.
    Quote Originally Posted by Razorhog View Post
    I was actually wondering how pollen looks on the floor bottom? We have a huge oak in the yard around the pool.
    One thing I haven't tried that many posters suggest in the forums, is to tie a sock to the return and catch blowout.
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    1,128
    Re: Possible algae?
    I have to say, the Intex auto cleaner does a great job picking up fine dust. It attaches to the return, not the intake, so the stuff on the bottom of the pool never even gets to filter.
    Quote Originally Posted by LoriWilfer View Post
    Pollen can look a lot like algae! Try the sock or hairnet trick and let’s see what you catch!
    Apr 2017
    Lake Charles, La
    15
    Re: Possible algae?
    Lol We have him too. I ran him after all the hand vac'ing to waste, and it picked up a little sand and dirt, but after backwash and rinse, once the pump began filtering after 2hrs I was back with this.
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    470
    Re: Possible algae?
    Put a knee-high panty hose on the skimmer basket and see if it's catching pollen. It acts as a pre-filter and catches a lot of stuff. Just keep an eye on it to make sure it doesn't get clogged and starve the pump of water.
    Edit: you can also use hair nets. 100 for like 6 dollars on Amazon Link: http://a.co/9D4VKrV
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    1,128
    Re: Possible algae?
    So your Intex cleaner is on your return and you still get this debris? Or did you remove him?
    Apr 2017
    Lake Charles, La
    15
    Re: Possible algae?
    When I hook the vac hose to the return, it cleans the floor great (unless what Im fighting just dissipates) but after I take him out, backwash, and put the pump back on filter, we end up with the same issue after a few hours...its extremely frustrating.
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    1,128
    Re: Possible algae?
    You may be backwashing too much. Sand filters clean better when they are a bit dirty! I think I backwashed once, maybe twice, all last summer.
    I leave my cleaner connected all the time. I hoist him onto the steps about once a week to clean his basket.
