Thread: dirt ring in skimmer
    Mar 2016
    Baltimore, MD
    37
    Hello,
    I have a dirt ring in my skimmer
    and was wondering if a special cleaner is needed, or is something like simple green ok to try? I just don't want to screw up any chemistry. I kind of doubt it with the small amount of cleaner needed compared to the entire pool. But wanted to run it by everyone here first.
    I do have an SWG and need to update my signature for that.
    Thanks.
    24K white plaster IG pool (2016), Jandy DE, Jandy 1.5 HP pump, Polaris 280 cleaner, Hayward AquaRite 900 series SWG, Hayward H400DN heater
    Jun 2014
    17,961
    Re: dirt ring in skimmer
    Inside there you have many options. I like to start with just elbow grease myself and use either a green kitchen scrubbing sponge or a Magic Eraser. Those should work well on the plastic without any cleaner at all. If however you feel a cleaner is needed, stick to what you use already in the pool - some water & bleach or perhaps a little water and acid mixed 5:1. In almost all cases for me, the elbow grease and one of those items above worked well for the skimmer and even a scum line if it develops around the waterline. Happy scrubbing!
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    617
    Mine wasn't that dirty, but I used the magic eraser like Pat mentioned and it cleaned it very well.
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,630
    Same here, magic eraser works great!
    Dolphin E10 Cleaning Robot.
    Mar 2016
    Baltimore, MD
    37
    Thanks all, I'll give the eraser a shot.
