Thread: IntelliChem - sick of the ORP probe!
    Aug 2015
    Central, NJ
    146
    Hi all,
    I've had an IntelliChem for a couple years now and have gone through a few ORP sensors already. I keep having inconsistent ORP readings. The reading seems to randomly be set. For example, one day I might have an ORP of 450 but a FC of 3, but then the next day might have a ORP of 750 and a FC of 2. I'm pretty good about keeping all the other chemical levels in the water where they need to be, and winterize the IntelliChem and probes according to Pentair's recommendations. Being that I've gone through a few of the probes already I pretty much don't want to deal with it any longer. I suppose I could try to narrow down if there's an issue with the wiring or the main unit, but based on how many people don't recommend using ORP automation, I'm leaning towards just having the system product a set amount of chlorine per day - that's an option, right? If yes, does anyone have instructions on how I can update the system to do so? Also - does anyone have recommended settings for such a setup?
    Thanks!
    PS - it's not all bad, as I love the pH automation - just fill the tank and it automatically dispenses as expected (and maintains the right pH level, based on what I've set it to be).
    In-ground 47'x25' free-form gunite pool w/ spa w/ waterfall. 35,380 gallons. 3' to 8' deep. 96 sq ft 6" deep sun shelf. SunStone Select Quartz Finish (Graphite). 2 Hayward skimmers. Jandy DEV60 DE Filter + Pro Series Plus 2HP Pump. Polaris PB4-60 Pressure Cleaner Booster Pump. Raypack P-R406A Heater. EasyTouch 8. IntelliChem w/ Acid Tank. IntelliChlor IC60. Techo-Bloc bullnose coping + Blu 60 mm paver patio. Merlin SmartMesh cover. TF-100.
    41,193
    Re: IntelliChem - sick of the ORP probe!
    This is exactly why we generally do not recommend the use of ORP sensors especially for outdoor SWG pools.
    You are better off just running your SWG in its normal % output mode.
    Sorry, I am not sure how to change the programming on that setup. But, I am sure the manual explains it.
