Thread: need good deck plans
    Aug 2009
    Keene, Texas
    157
    I have a 24 round pool, 54" wall, and want to build a deck at one end of it with maybe a lower deck leading up to it with inset stairs and gate. Does anyone know of some good deck plans for something like this or similar (or even not similar but nice) that I could get? I am not good enough to just start doing it, but if I have plans then I think I could follow them and do it myself, thus saving myself some dough.
    amoses (Aaron)
    Converted from Baquaqoo in the fall of 09. Best thing I ever did!!
    AG, 24 Ft Round, 54" wall, 48" deep, 13,500 gal., TF-100 test kit
    Hi-Flo II 1.5 HP pump, AquaTools High Rate 200# Sand Filter AT3120
    Mar 2007
    Texas
    444
    Re: need good deck plans
    deckplans.com
    27' Round AG, 17,200 gallons, sand filter
    Aug 2009
    Keene, Texas
    157
    Has anyone used the dek blocks? do they work good? I had looked at those plans before but was not sure about the dek blocks.
    amoses (Aaron)
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by amoses
    Use the Google Search, bottom left, and you will find some threads
    You're done SLAMing when:
    Mar 2007
    Texas
    444
    I used the deck blocks on mine, It has been up for about 5 years. Worked great and have had no problems.
