Results 1 to 13 of 13
Thread: POols up!
    Jul 2009
    Houston, Tx
    19
    POols up!
    The pool arrived this morring, and despite my best efforts, I managed to fubar the install. I had carefully measured, placed, and dug out my concrete blocks for the pool legs to sit on, and somehow devided 18 by 2 and got 8. When I had finished pre-assembling the top ring, I noticed the legs would not be on the blocks. Then I noticed the "extra" top rail and "T". I measured the stone placement 10 times if I measured it once, but I didn't think to check my math. What a pain. Anyway, after a couple more hours of discussing this problem with myself, the pool is filling. Slowly I might add, but filling.
    Played with my test kit and found my PH is 7.5, but my TA is above 200. Will be adding salt, bleach, CYA, and acid as soon as I can get the pump running. Thanks to everyone here for the great cite and all the help.
    Intex 22 x 52 Ultra frame, 10,400 gals
    Intex 2600 gl/hr sand filter
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Re: POols up!
    John,
    Congrats! Now you have to take some pics and post them!
    My kids love the Utra-Frame pool, it also went up alot easier than the reg frame.
    Here is mine:
    Let us see yours! LOL
    Mike
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    Jun 2008
    Wichita, KS
    22
    Re: POols up!
    Quote Originally Posted by gd5015
    Why do you want to add acid? Your pH (7.5) is fine and the CYA will lower that anyway. You will most likely need to add borax to raise it after the CYA.
    10k gal. IG vinyl, 1 hp pump, 200 lb sand filter, solar panels & cover
    Re: POols up!
    You may want to just wait and monitor the pH before you try to adjust the TA, it may or may not really be necessary. You can do it the slow way and just add MA when the pH gets to 7.8 and reduce to 7.2 or so and let that wear down the TA slowly.
    Doing it rapidly requires aeration and if you want to you can find some things that folks here have devised to get a lot of aeration quickly in above ground pools.
    But, you may not NEED to. Not right away.
    to yitbos1, CYA won't have any real effect on pH, that is MA, muriatic acid that does affect pH and eventually TA.
    Jul 2009
    Houston, Tx
    19
    Re: POols up!
    Thanks for the suggestions, maybe I will wait and see on the acid, but I thought TA was pretty important for a SWG.
    Ended up draining the pool today anyway. The frame twisted while the pool was being filled. I saw it happening as I was filling, but had no idea just how much it would twist. Can't keep the legs on the blocks now. The legs easily shifted 6 inches. Also, the bottom rope stretched. I cinched it up pretty tight when there was only a few inches of water in it, just not enough. And the legs moved back another 6 inches. Anyone see a pattern developing? Apparently these pools are not for the feint of heart.
    On the plus side, the pool is level to about a 1/2 inch. I was pretty impressed with that. We did swim late last nite and again this morning and I could get to like this. Just have to get it right this time. I was also impressed with the Intex pump. The return is quite strong. Any reason why I can't use the existing pump with a larger cartridge filter? The ladder however, stinks. But for $600 shipped, I can't complain. Will post pics when I get it back up. Hopefully, tomorrow afternoon.
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Re: POols up!
    I've been considering getting the 18'x52' as well but prices vary wildly for this.
    Where did you find it for such a good price?
    On a side note, I know the stronger intex pump will run a sand filter because I had to use it when my other pumps wet end failed. It's even strong enough to run the auto vacuum.
    Glad I kept it for a backup and I will continue to keep it for use as such.
    Intex 15' X 48" metal frame pool
    Waterway Supreme 1hp 2 Speed pump
    Hayward X-Stream 150 Sq. Ft. Cartridge Filter
    2-2'x20' Sungrabber Solar Panels hooked up in parallel on a Goldline GL-235 controller.
    Not getting "Pool Stored" = Priceless!!!
    Thank you TFP
    Jul 2009
    Houston, Tx
    19
    Re: POols up!
    http://www.meijer.com/catalog/product.j ... oryId=1993
    This is where I got mine. It was on sale until the first week in August, $630 and free shipping. The week after I ordered mine, they sent me a 15% off coupon, but wouldn't apply it retroactively. The shipping took a few days shy of 1 complete month! So I wasn't really fond if the idea of canceling and reordering it. Not much summer left as is.
    Got the pool drained over nite, and started working on it this morning. That last 3 inches of water is tough to get rid of. Got the legs back on the blocks, made sure they were vertical, and cinched up the rope as much as I could. What a PITA. I hope I never have to take that pool down again. While it was filling, I did put a small deck together since the supplied ladder is so awful. At least it is for a 230 lb, 50 yr old man. Wobbling around 7 ft up in the air is not my idea of fun. Pics. to follow.
    Jul 2009
    Houston, Tx
    19
    Re: POols up!
    Finished filling this morning and added about 50 oz. of 6% bleach. Then I worked on the 4x4 deck / stair a little and swam a little. Not a very productive day, but it was really nice to be able to jump in when it got a little hot. Test numbers from tonite are:
    TC 0 - added 50 oz. bleach to get above 5
    pH 7.5-7.8
    TA >150
    CH 70
    CYA is dissolving in a stocking, so I guess my FC from this morning was eaten up by the sun. I added another 50 oz. of bleach tonite. I need to get another batch of salt, but will wait a few days to get the water balanced.
    I fixed my part of my leg problem. They are no longer twisting to the side. But they are still being pushed back by the pool. Is this normal? Spent a good while making sure the rope was cinched good and tight, but with all that weight pushing out on it, it is going to stretch. Don't know what else to do. By the time I got everything cleaned up enough for pics, it was getting dark and I needed to hook up the strainer and vacuum. So far, except for the ladder, I'm pretty impressed with the level of quality on the Intex pool.
    Jul 2011
    Bath Pa
    29
    Re: POols up!
    anyone know which is the best auto cleaner for intex ultraframe pools ?
    Robin
    central new jersey
    24x12x52 intex ultraframe swg 1650 sf
    Re: POols up!
    Pics. to follow.
    Still waiting on those pics...
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Jun 2012
    Goochland, Virginia (outside of Richmond)
    32
    Re: POols up!
    We purchased the Dirt Devil auto vacuum for our above ground pool (previous pool). We got it on sale for about $100.00, it only has one moving part. It has a counter weight that the water flow moves back and forth thus scooting the unit around the pool. This is a suction side cleaner that pulls the trash and debris into the filter. We used this for 2 years and it now resides in another county still cleaning the above ground pool. It is not perfect and it works randomly, but it will do the job in a few hours. You can adjust its pattern somewhat by adding or subtracting a length of the included hose.
    I ran this for a few hours about twice a week and besides occasionally (every few weeks) taking the included hose and sucking up some random dirt in a location or two (5-10 minutes of work max) I did not vacuum for two years, except after a storm or high wind.
    16,800 16'x32' IG Vinyl Pool, Buddy Seat, 7' Deep End
    Hayward Sand Filter(1.5 cups of DE), Pentair Pump, SWG Autopilot Digital
    Taylor K-2006 test kit, Speed stir, Borate and Salt Water Strips
    Polaris 9300 cleaner
    Pool Filled First Time June 14th, 2012
    Previous Pool AG Intex 16' Oval, SWG (5 Years)
    Jul 2011
    Bath Pa
    29
    Re: POols up!
    thanks bacpck
    Robin
    central new jersey
    Apr 2012
    SW Ohio
    456
    Re: POols up!
    Are you planning on any mods to your pool?
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
