Trouble keeping Ph and TA down
DaveInPhx
In The Industry
Apr 8, 2009
28
El Mirage, Arizona
My target #s are ~80 TA and ~7.2Ph.
I'm having to add about 1 gal. of 34% MA a week to keep the Ph/TA at these levels.
The pool was re-plastered in May, so I realize this will create a need to use more acid, but two things bother me. First, the amount of acid I'm having to add has not decreased at all since May and seems to have increased some. Second, prior to having the pool re-plastered I was still having to add (what I consider) quite a bit of acid at 1/2 gal a week. Is there something else that I should be looking at that would contribute to this rise in Ph/TA?
Also, I didn't add acid for 4 weeks and Ph was off the charts and TA was around 400 by the time I got back on track. My SWG element would get covered in the white toothpaste stuff after just a couple of days to the point it would essentially stop producing any measurable chlorine until I hosed it off. I thought my element needed to be replaced but now that I'm adding acid regularly it seems the buildup is back to normal. What is the white gunk that builds up on the element and why does it seem to be affected by Ph/TA?
I don't think TA could go from 80 to 400 without something being added to the water. It seems that everybody in Arizona has problems with calcium in the water. Are you testing for calcium hardness?
The acid demand for your new plaster may go on until next summer.
It probably wasn't 80 to 400. It was probably more like 120 to 400. I was letting it run a little high just because I was tired of adding so much acid. As far as I know, nothing has been added to the pool. Just people swimming.
The last time I took it to the pool store to have it tested (I don't have a kit that will do this) the CH was 380-ish. High, but not through the roof. It was about the same the time before so I don't believe it's fluctuating.
So 1 gal a week is normal with new plaster then?
I add acid at about the same rate. We have the spill over spa which drives the Ph up and the acid drives the TA down I have been keeping it has been around 60 - 80 for the last couple of months. Our TA goes up when new water is added or when the wind blows dirt into the water. I am guessing that it isn't the wind but alkalinity in the soil here.
Our pool was plastered in May as well. No SWG I understand it that will drive your Ph up too.
I understand about getting tired of the acid add game. There is a brand of MA at the pool store that is labled "AZ Formula" "made for the desert" leads me to believe it is just part of having a pool in these arid areas.
I agree with mickey4paws your own test kit is important, you can not know what is going on if you are not watching the water chemistry and staying ahead of it. By the time you see it with your eyes your behind it, clearing up a mess of one kind or another.
mickey4paws said:
Hi Dave,
I would recommend you get your own test kit. The TF100 is the one I have but there is also the K-2006. I have found that pool store testing can be very unreliable. Here's a link to the test kits:
pool-school/pool_test_kit_comparison
I already ordered one (TF100) and it should be here by the weekend. :)
This pool has always been sparkling blue using a basic chlorine/Ph/TA kit but I'm going to start working on my brother's pool which doesn't look so good so I figured it was time to get something more than a basic kit.
Yeah, this is the stuff I get because it's the highest % I could find and the best value. I figured the "AZ Formula" was a sales gimmick, but you think they add something to it that's not in the other stuff?
