Results 1 to 10 of 10
Thread: First time having a pool
    Apr 2018
    Van Texas
    14
    Hello, I have never owned a pool and this weekend I am going to start installing the one in my signature. Can anyone answer a few questions?
    1. Is it necessary to compact the soil with a plate compacter?
    2. Can anyone send me a link or just list the steps I need to take after filling it up with water?
    Thanks
    Pool info - Intex 32 x 16 x 4-3-Foot Ultra-Frame Rectangular Pool15k Gallon, all Intex Brand. Bought online at Walmart if you need more info
    Converting to Salt Water- SWG -Intex Krystal Clear Saltwater System, also bought at Walmart online.
    Jun 2014
    17,961
    Re: First time having a pool
    Welcome to the forum! For your questions:
    Necessary, perhaps not, but certainly ideal. For a good pool, it's ALL about the base. Not sure about your area, but around S.A. we have tons of weeds and roots that grow through just about anything. Often times pool owners will cut a thin layer of soil, spray an algaecide, then cover with a protective base material like Gorilla Pad, insulation, or something of the sort. Remember to always cut down (not fill) if there are areas that are not level.
    This is your very basic sequence, post back with full test results for more help:
    - Add stabilizer via the sock-soaking method; use the Poolmath calculator for a starting CYA goal - a CYA of 40 should be a good start this time of year.
    - Add regular bleach for a starting FC of 2-3 ppm. Once the stabilizer is in the water, increase the FC level to about 5-6.
    - Check pH and keep it between 7.4-7.7; if it goes over 7.8, knock it down with muriatic acid.
    As for the SWG, once you have it installed and ready to use, you'll do the following to convert:
    - Add the required amount of salt and let it dissolve and mix well
    - Increase the CYA to 70
    - Set SWG % to about 50-70% and monitor the FC output; test FC 2-3 times a day to ensure the pump/SWG are producing FC as required.
    - Maintain the proper FC/CYA level as noted on the Chlorine/CYA Chart (link below)
    With the proper test kit (TF-100 or Taylor K-2006C) post a full set of results and we'll help you from there.
    Hope that helps.
    Apr 2018
    Van Texas
    14
    I was going to install everything at one time pool, pump, SWG everything. Is this not a good idea?
    Apr 2018
    Van Texas
    14
    I am not using a gorilla pad but where I work has sheets of very dense foam rubber I am putting under it. and its 7/8" thick so nothing should grow under it
    Jun 2014
    17,961
    Perfect. Everything above still applies (start with small amount of bleach for FC of 2-3, adjust pH, etc) but for CYA go directly to 70. Keep some bleach handy though while you wait for the salt to dissolve and for the SWG to get dialed-in. But yes, go for it!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,203
    Level, level........and oh yeah.....level.
    Apr 2018
    Van Texas
    14
    Can you tell me all the names of the tests I need for my pool seperatly?
    Jun 2014
    17,961
    Apr 2018
    Van Texas
    14
    I am finally filling up my pool. I am about 6 inches of being full. The Sides of my pool are still bowing is this normal or is something wrong?
    Jun 2014
    17,961
    Something sounds odd. You should probably post a pic for us so we can see. We have some AGP experts who might light to see you situation.
