Thread: Hayward Pump Specs
    Hayward Pump Specs
    Aloha all. I got a Hayward Super 2 Pump without the motor and the specs say that it can take from 1/2hp up to a 3 hp motor. Although 1/2 to 3 hp is a lot of difference, I do not see what pumping GPM will change if it is the same pump. (obviously a 1/2 motor may be straining to maintain 3450 rpm, but I do not see a 3 hp motor pumping even double the GPM, let alone the 6x difference in size. Can someone explain? thanks
    Frank
    7800 Gal. 8' wide x 20' long x 7' deep
    Hayward 1200 Cartridge 7200 GPH, Waterworks 1/8 hp 2400 GPH
    Made from 20 Container Lined with "PolyUrea/Rhino Lining"
    Workshop, welding etc,+office+living area running off grid on 10kw PV
    strasburg,il.
    11
    Re: Hayward Pump Specs
    go to haywards web site and look at the parts sheet for those pumps and you`ll see what is differant about each one.IM not positive on the super pump. BUT their power flo pumps just use a differant size impeller to go with the differant size motor hope it helps some.
    laguna portable pool 13x25 , 9k gal , hayward 16" sand filter,hayward power flo lx 1hp pump. tf test kit
    Yup,thats it. Same housing, different impeller/diffuser. thanks
    Frank
