Results 1 to 7 of 7
Thread: water test results
    fordman's Avatar
    Jul 2009
    Iowa
    119
    water test results
    Well had my water tested last week and everything ok but cya was 7 added 25 oz of walmart hth stabilizer. This weeks test are.
    FC .5
    TC .3
    CC -.2
    PH 7.8
    CYA 26
    TA 100
    Cal hardness 263
    Temp 75*
    Added the 25 oz that the pool cal. said to get to 40 but only 26 was it bad or cheap stabilizer or not a good test? Test machine was a pinpoint computerized water analysis system.
    1988 Ceder Ridge
    24' Doughboy AGP
    Jul 2009
    London and France
    574
    Re: water test results
    Well Fordman if everything was OK you have put a decimal point in front of your FC (0.5) which is too low look again at the CYA/Chlorine chart.
    fordman's Avatar
    Jul 2009
    Iowa
    119
    Ok I know it's not ok but I need to put in I know my fc was low when I took the sample. Added after sample because was mainly looking for the TA and CYA numbers.
    1988 Ceder Ridge
    24' Doughboy AGP
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    testing your own water would be ideal. here is another recent pool store cya testing problem: one-more-new-to-bbb-and-clueless-t16295-20.html
    if you didn't reach your goal, add some more. sometimes pool volume calculations can be off, pool store testing is often inaccurate, etc etc etc. keep at it until you reach your target.
    Jul 2009
    S. California
    157
    I had to add three pounds of Dichlor (48ounces) to get my CYA from 0 to just above 30. Seems that with your pool's volume you will need more. Also, it took several days before the CYA test would correctly register the level. Maybe you need to wait a day or two and retest for CYA.
    FYI, I used "Chlor-Brite" from Leslie's, and they sell it in 1# bags. Just Dichlor and chlorine with no nasty minerals.
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
    fordman's Avatar
    Jul 2009
    Iowa
    119
    I am going to purchase a test kit next spring since in a coulpe weeks to a month pool will be taken down for the year. Can't see me buying a kit now and have it sit all winter. Looking foward to next year with all the info I have learned from this site and the very helpful people.
    1988 Ceder Ridge
    24' Doughboy AGP
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by Livinright
    Chlor-Brite = dichlor = chlorine + CYA. Still no nasty minerals, though.
    --paulr
    BBB "Intermediate Swimmer"
