Results 1 to 7 of 7
Thread: Using KI and Thiosulfate Titration for FC. What about CC?
    Jul 2009
    Eden Prairie, MN
    37
    I'm using the old standard method.
    1 liter water sample
    Add 10 mL of 20% sulfuric acid to lower pH.
    Add 10 mL of 10% potassium iodide
    Titrate with 0.1 N thiosulfate to faint yellow
    Add starch
    Continue titrating to colorless.
    mL of 0.1 N thiosulfate x 3.55 = total chlorine
    Should I be worried about only testing for total chlorine?
    What about combined chlorine? Is CC a rare issue?
    I found this about using spectrum analyzer.
    http://www.asaanalytics.com/total-chlorine.php
    2. Idiometric Analysis
    This is the method of choice where the application requires control of the specific forms of combined chlorine, such as water chloramination monitoring and control (See ChemScan Application Summary # 86, Water Chloramination Process Control). This method is based on the principal that free and combined chlorine will proportionally liberate free iodine from potassium iodide. Free iodine has a strong UV absorbance signature, such that a full spectrum analyzer like the ChemScan UV-2150 can be used to detect the liberated iodine, plus compensate for other oxidizing or reducing agents or interferences in the background (including monochloramine - which can be independently detected), and calculate the resulting concentration of total chlorine. This is also the method of choice if multiple sample lines are being monitored or if other parameters are analyzed in addition to total chlorine. Typical range is 0.05 mg/l to 10.0 mg/l, but can be altered based on path length selection.
    Any info or opinion on this method?
    Thanks for any comments.
    AGP partially buried, with surrounding deck and flower bed. 12 x 24 oval x 48" deep Celebration by Forum. Steel sides, vinyl liner. Hayward 2 HP sand pump. Flower fountain - works well to cool water up to 10 degrees.
    Mar 2009
    Auckland - New Zealand
    48
    Re: Using KI and Thiosulfate Titration for FC. What about CC?
    surely a test kit would be a lot easier ?
    Montreal Canada
    326
    Quote Originally Posted by SBax
    That's (almost) the way the Taylor Bleach test is done - but using smaller sample size and reagent quantities.
    You're better off using the drop-count titration of FAS-DPD, smaller sample size, smaller volume of reagents are used, basically simpler to perform, all the reagents are already prepared, the precision is there too, +- 0.2 ppm, and you easily differencitate between the free and combined forms, and it's also listed in Standards Methods. The iodometric method is fine if your sample contains high levels of chlorine, but with the small concentrations used in pool water you'd be better off with FAS-DPD.
    Jul 2009
    Eden Prairie, MN
    37
    Yes, a test kit is easier but I work in a lab with excellent equipment. I can easily check Cl2 and also measure pH on a research grade pH meter. I know it's overkill but obsessive minds need to know. I'll check TA weekly and CYA as needed.
    Jan 2009
    Cupertino, CA
    1,966
    But how long is your commute? As I recall, one of the contributing factors to pool-store testing problems is that a long interval between taking the sample and doing the test will make the FC and pH readings somewhat suspect. You can lose FC, and pH will drift if the temperature changes.
    --paulr
    BBB "Intermediate Swimmer"
    Jul 2009
    Eden Prairie, MN
    37
    I used a pre-treated glass sample bottle and the pH meter has temperture correction anyway. 15 - 20 min commute.
    Montreal Canada
    326
    Have fun! It must be cool to play with all that equipment! But keep in mind in all of this that you're dealing with a swimming pool, where the actual volume is very approximate (and varies). It's precision work in a world of uncertainty.
