Any thoughts on the equipment?
Others here are much better suited for equipment comments, but I've had good luck with my Pentair gear. I only see one red flag in that pile'o'goodies, the salt. There are threads here that describe PBs putting the salt in on day one, and that always gets a backlash of comments. There is a clear consensus here to wait 30 days or more before adding salt and firing up the SWG, backed up by at least one very well respected scientist/TFP-expert, that I believe knows more about plaster startup than most, and he is clearly adamant about it. Salt water and brand new curing plaster do not mix. The National Plasterers Council (NPC) and their startup card for plaster gets mixed reviews here, but they, too, are quite clear about the 30 days. Since it does absolutely no harm to run your pool as non-SWG indefinitely, if it were mine, I'd wait (and I did just that, six months!). Have a conversation with your PB about his intentions with the salt.
Tip'o'the'Day?
As you get closer to fill day, you'll get some great tips about how to put the water into your pool (I'll share 'em if no one else does.). Of all of them, this is perhaps one of the most important ones. Once you start the fill, DO NOT STOP IT FOR ANY REASON. Doing so can cause a ring around your whole pool which won't come out. Fill as fast as you can, in one continuous stretch.
Tip'o'the'Day-2?
Did I give this one to you already? I don't see a test kit in your signature. You should by now have bought one of the two TFP-recommend test kits. Don't wait if you haven't. The "5-Way" you just received has a purpose, and you'll be able to use it a bit, and it will be a good backup so it won't go to waste, but once you get into water testing and adjustment (starting on day one of the fill), you'll want to, and be expected to, give TFP proper test results, and for that you need a good kit. (Assuming that you'll want TFP involved for your startup.)
This one or
this one. But the real tip is to
start using in NOW. Fill day is stressful, and your tasks will be fast and furious. Testing is imperative, and critical for a proper plaster startup, and you don't want to wait until that day to start learning your kit. Get it now. Use it now. Start with testing your fill water. You'll need that data anyway. Test for everything except CYA (that'll make sense later, just remember it). If you can borrow a neighbor's pool water, test that, too (they'll thank you, or curse you for finding out their Leslie's Pool Store Water is all messed up). Point is, you want some testing experience under your belt come day one. Please trust me on this, or forgive me if you've already got this covered.
Tip'o'the'Day-3a?
I keep trying to sell this one, with mixed results. Take it or leave it, but I believe in it and it has helped me immensely with balancing my pool. You've got an irregularly shaped pool, and it'll be tough to calculate its volume. And that number is at the heart of how you'll ascertain the proper amount of chemicals to add. There's a super-easy way to get a very accurate number, but you only get one shot at it. Interested? Right before they start your fill, find your city water meter and take a picture of it. As soon as the fill is complete, take a second picture of the meter. Subtract the difference between the meter readings, do a little simple math if the meter isn't in gallons (or I'll do it for you), and you'll have the exact number of gallons of water in your pool (well, within the 1% margin of error of the typical water meter, anyway). Here's a few extra tips to improve the accuracy of the number if you really want to dial it in. Use as little water in the house during the fill as possible. Turn off any irrigation. Take your showers before or after the fill if you can. Take a break from dishes and laundry, and/or go out and celebrate your new pool with a nice dinner, elsewhere. Count the toilet flushes and subtract that number x a gallon from the water meter math. But even if you ignore all that, you can use your house water normally, and just subtract a hundred gallons or so from the meter math. Either way, you'll end up with a far more accurate number than you'll be able to come up with trying to calculate the geometry of your pool.
Tip'o'the'Day-3b?
Whether you use the meter trick or not, you'll probably be expected by your PB to monitor and stop the fill when your pool is full. Your PB should tell you where "full" is, but it's typically half way up the skimmer opening. Problem is, while that's easy to see when the pool is empty, it can be deceptively challenging to find halfway when there is water in the opening. The reflection and the refraction of the water will play tricks on you. So when the PB shows you where "full" is, put a piece of tape there to mark it.
It won't be long now!!!
3b isn't critical, by any means, because if you miss exactly where "full" is, the autofill will get adjusted and straighten that out. I misspoke, marking the "full" line with tape is really only about the meter trick, if you pursue that. If you're trying to determine how much water is in your pool, you want to stop the fill, and get that second meter reading, when the pool is at, or at least very close to, the level it'll normally be at. If you read the meter when the pool is a couple of inches up or down, then your "normal water volume" number could be off by hundreds of gallons.
