Pool has been green for about 7 months. Started SLAM when I received my test kit Wed. afternoon and ran out of FAS-DPD Reagent Thurs. afternoon. Ordered large refill which i received Sat. I continued to add 10% chlorine while waiting on the refill. when I tested after the refill arrived FC was at 7ppm. current readings
are
FC 19
CC 1
PH 7.2
TA 60
CH 140
CYA 50
I've been shocking at 20ppm and running the pump on high speed since I've started and the color hasn't changed at all. I've put a total of 19Gal of Walmart 10% chlorine since Wednesday. Is this normal? I had to run the CYA test with the pool green. Any ideas or suggestions? Thanks
are
FC 19
CC 1
PH 7.2
TA 60
CH 140
CYA 50
