Thread: Zodiac DEAD. which dolphin should I get? Or just buy a new Zodiac?
    Feb 2017
    Texas
    36
    Hi guys, my Zodiac just died. The black tracks kept slipping over and over and then finally the clamp that holds the tube together just broke apart. I was meaning to eventually upgrade to a dolphin. Is that the best robot out there?
    Which models do you guys suggest for a 25,000 gal inground? I want something that would be able to scrub a little too.
    Also, where would be the best place to buy on the cheap?
    Thanks!
    Approximately 25,000 gal + spill over spa, IG, Gunite (I think), Hayward C4025 Cartridge filter, Pentair VS 3HP 011018 Pump, Raypak 399 BTU NG Heater, TF-100 Testing Kit
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,266
    Re: Zodiac DEAD. which dolphin should I get? Or just buy a new Zodiac?
    Dolphins arenít cheap, as you request, but Marina Pool and Spa by phone is a good choice and they are the best choice of robots.
    For refurbís you can try poolpartz.com. Thatís what I did.
    Iíd recommend frankly either the S or M series. The S series has many twins as well. Some may say the S is not as suited for large pools but ours is 27K and itís fine. Goes top to bottom side to side. A longer cycle might be nice but two hours is fine unless itís really dirty.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Feb 2017
    Texas
    36
    Quote Originally Posted by bmoreswim View Post
    Dolphins aren’t cheap, as you request, but Marina Pool and Spa by phone is a good choice and they are the best choice of robots.
    For refurb’s you can try poolpartz.com. That’s what I did.
    I’d recommend frankly either the S or M series. The S series has many twins as well. Some may say the S is not as suited for large pools but ours is 27K and it’s fine. Goes top to bottom side to side. A longer cycle might be nice but two hours is fine unless it’s really dirty.
    Thanks!
    I Just talked with the guys at poolpartz.com. Great knowledgeable people! They have a refurb M400 for $999. What do you think? Its 2017 model. Is it worth it? Anything the new models have that I will miss not having?
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,266
    The M Series thread has a comment that the refurb price on that model currently is not competitive with a new one from Marina.
    Sep 2009
    Houston, TX
    163
    Just paid 999 for m400 new at marina. So a refurbished one for the same price may not be a great deal.....
    15000 Gallons In ground, Ecofinish, sand filter, Pentair intelliflo VS, SWG
    Feb 2017
    Texas
    36
    Quote Originally Posted by eric99gt View Post
    Roger that, I'm buying the new one from Marina today!
    Thanks!
