Thread: Chemical safety
    Mar 2018
    Florida
    42
    Chemical safety
    First time adding chemicals. Is there a post that reviews the safe ways to handle, store, measure all my chemicals?
    Anything specific to 31% MA? (Also is 31% the same as 29% in PoolMath app for measuring purposes?)
    Wear gloves? Masks?
    POOL NOOB:Size: 15,500 Gal, Type: Plaster/Concrete IG pool, Filter: Hayward Star Cleaner - Cartridge Filter, Pump: Hayward Max-Flo, Heat Pump: AquaCal Heatwave Superquiet, SWG: Pool Pilot Digital by Autopilot, Test Kit: Taylor K-2006 FAS/DPD Chlorine
    Jun 2014
    17,961
    Re: Chemical safety
    We talk about it some here: Pool School - Re: Pool School Pool Safety
    The big one for MA is to not add at the same time as chlorine/bleach. Of course it's volatile, so be mindful of the wind (vapors) and splashing to the skin and eyes. Add very slowly near a good flowing return jet and brush if needed to help get it around. It can be stored outside in a shed type container, just make sure to store it away from metals or any other products as it is very corrosive.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,203
    Re: Chemical safety
    Don't sore it NEAR bleach or pucks either.
    Donldson's Avatar
    NW Ohio
    3,262
    Re: Chemical safety
    I would actually encourage NOT wearing gloves and a mask with MA. Splashing MA on your hands is very unlikely to cause any damage as long as it is rinsed off relatively quickly. As far as a mask, your nose is the first to warn you if MA vapors are heading towards your face. MA vapors are very noticeable well below the dangerous level, if you get a whiff of them then you know to change where you are positioned and stop breathing in until you do. If you can't smell it then you could end up standing in a bad spot too long and end up irritating your eyes from the exposure.
    One of the most mind boggling threads I recall reading is about someone who wore a mask, gloves, goggles, and apron to pour MA and still managed to gas himself and ended up going to an ENT doc. His sense of safety caused him to stop being careful and he didn't seat his mask correctly and because he assumed he was safe deeply breathed in fumes.
    Just be mindful of what you are working with and the wind direction. Pool chemicals are not overly dangerous and an ounce of common sense and awareness can prevent almost any problems.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
