Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
Thread: Post up pics of your cantilever umbrellas
  1. Back To Top    #21
    Join Date
    Feb 2018
    Location
    The Colony, TX
    Posts
    158
    Re: Post up pics of your cantilever umbrellas
    @Arizonarob - I could be wrong, but I don't think a typical umbrella sleeve is strong enough for the cantilevered umbrellas. We are looking into it and most of the anchors require the pole to be deep set in concrete. Will probably end up with something like this in the grass at the pool edge:
    Treasure Garden In Ground Mount Kit For AKZ Cantilever Umbrellas Only | AMK-G
    But please post if you find something!
    Started building 4-5-18! 40x15 IG Approx 15,000 gallons? /TF100 Test Kit / Ocean Blue PebbleSheen / Jandy CV460 Filter/ Jandy PLC1400 Salt System / Jandy VSSHP270AUT VSP / Jandy JXI400N heater / Jandy PSB215 Pool and Spa Blower / iAqualink / Polaris 280 / New Geometric IG Pool in DFW
  2. Back To Top    #22
    Arizonarob's Avatar
    Join Date
    Mar 2018
    Location
    Chandler Arizona
    Posts
    498
    Quote Originally Posted by LeighHop View Post
    Well thanks for raining on my parade!!
    I’m just kidding. But I do like that sleeve kit. I wonder if it is designed to only work with their 500 dollar umbrella they sell, or could it work with others?
    I was looking at using a cheapo umbrella just to give some shade in the pool area on each side, that’s why I figured if the poll would fit the current sleeves, the umbrella wouldn’t be two heavy.
    I can basically make a sleeve anywhere around the pool with some simple PVC and set it in concrete with a cap when not in use.
    Thanks for that link, I’m going to do a little more research on that thing.
    ~Rob
    11,000 gallon in ground plaster pebbletech finish. Hayward Tristar VS, Hayward Swimclear, and Hayward Aquanaut 200 pool vac. K-2006 Kit. Speedstir
  3. Back To Top    #23
    Join Date
    Apr 2012
    Location
    Newton, NC
    Posts
    186
    We just recently added this cantilever umbrella to our pool area:
    I took the picture around 9:45 am. The shadow from the umbrella is on the decking. But, from early until late afternoon, the umbrella shades about 20% of the pool.
    The umbrella is from Amazon, but I just checked and it is no longer listed. You will notice that in addition to the base made for the umbrella (which I was able to stuff with about 130 lbs. of sand), I also purchased an additional umbrella base weight (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1). I have about 75 lbs. of sand in it. The most common problem I have read about cantilever umbrellas is that they blow over in the wind because the base is not heavy enough. I'm hoping 200 lbs. of sand will be sufficient.
    Vince L
    16' x 37' fiberglass pool, 8' fiberglass spa, Hayward Swimclear C3030 filter, Hayward EcoStar VS pump, Goldline Pro Logic PL-PS-8, Goldline SWCG, Goldline Sense & Dispense pH control, Fiberstars LED's in pool & spa, AquaCal SQ175R heat pump, SR Smith Typhoon slide, Polaris 9300xi robotic cleaner, TF-100 Test Kit
  4. Back To Top    #24
    ctrav's Avatar
    Join Date
    Apr 2017
    Location
    Northlake TX
    Posts
    1,236
    Nice pics of the cantilever umbrellas....now that y'all have had them a few months whats the verdict? How are they doing in windy conditions? My space has wind everyday and some days it truly blows. Thanks all!!!
    Cliff, IG, 22K gal, Pentair WF 2HP 2 Speed Pump, Pentair FNS Plus 60 DE Filter, Hayward PL Plus Pool Management, SWG T Cell-15, 2 LED Hayward Color Logic 4.0 Lights, Water Features, Diamond Brite Black Onyx pool finish, TF-100 Test Kit, PoolMath App, Dolphin S200 Robot (Phin). Northlake, TX New Pool Build
    I support TFP Forums ♥ Has the info saved you $? You can support too!
  5. Back To Top    #25
    kellyfair's Avatar
    Join Date
    Jun 2016
    Location
    Tampa, FL
    Posts
    1,966
    Jamison, I love your deck!
    And your whiskey...
    16' by 4' Intex Ultra Frame AGP
    Intex Sand Filter Pump & SWG
    Hayward Skimmer, Intex Auto Cleaner
    TF-100 & Speedstir
  6. Back To Top    #26
    Mod Squad pooldv's Avatar
    Join Date
    Aug 2012
    Location
    DFW, TX
    Posts
    24,748
    Ours has held up great so far. We are fairly protected by trees but there has been some pretty good wind and no issue with the umbrella being unstable when open or closed. And it's awesome! Almost as good as a robot! Well, maybe not that great, but we're happy with it for sure!
    TFP Moderator
    If TFP helped you or saved you money - Become a TFP Supporter! <--Click here
    2012 build and pics, 20k gal gunite, black onyx pebblesheen, OK flagstone, IntellifoVS, cart filter w/Pleatco, IC40 SWG, Solartouch, 5 12'x4' solar panels, HP50HA heat pump, 8mil solar cover, borates, TF-100 test kit, SONOS, Doheny's Discovery Robot, hot tub on bleach
  7. Back To Top    #27
    ctrav's Avatar
    Join Date
    Apr 2017
    Location
    Northlake TX
    Posts
    1,236
    The fact you mentioned umbrella in the same boat as Gilligan says a lot about the product! Thanks pooldv
  8. Back To Top    #28
    GOONiE's Avatar
    Join Date
    May 2018
    Location
    Chicago burbs
    Posts
    142
    40x20 30,000 gal vinyl - autocover - sand filter - Minimax NT heater - Hayward 1.5 single - TF-100 - well water
  9. Back To Top    #29
    ctrav's Avatar
    Join Date
    Apr 2017
    Location
    Northlake TX
    Posts
    1,236
    Dirk any pics of your setup?
  10. Back To Top    #30
    Join Date
    Aug 2012
    Location
    DFW, TX
    Posts
    24,748
    By the way, the base on my umbrella has 4 sections. Each section is filled with more than 50lbs of sand and then filled with water. It took a surprising amount of water to fill each one. I dont know how much each section weighs after being fillled with sand and water but i do know that i got tired of moving them while trying to get the base leveled. I would guess at least 4 or 5 gallons so each section probably weighs 80 to 100 lbs.
    TFP Moderator
  11. Back To Top    #31
    Revlus's Avatar
    Join Date
    Aug 2017
    Location
    Hillsborough, NJ
    Posts
    52
    We ended up buying FOUR?!?! of these Hampton Bay 11ft Cantilever Umbrellas on sale at Home Depot for $230 each. Built in LED lighting with solar charger. We had to buy sand to fill the base with. $4 bag for like 6 40lb bags for each umbrella. Very sturdy and high quality from what I can tell. Love how we can tilt them and block out the evening sun. It also rotates 360 and locks in place at each 45 degree. The dark red ones are very nice. Not too bright and gaudy.
    Built: 2005, 35k in-ground vinyl, Taylor K2006C, Sand filter, SWG died so manually maintaining for now with liquid chlorine so pool does have some salt in it, 2HP Whisperflo pump and 2" PVC, built in spa. Uses an old Polaris EOS system. Kinda sorta works. :-)
  12. Back To Top    #32
    kellyfair's Avatar
    Join Date
    Jun 2016
    Location
    Tampa, FL
    Posts
    1,966
    Those look awesome, Rev!
    TF-100 & Speedstir
  13. Back To Top    #33
    Jamison04's Avatar
    Join Date
    Jun 2011
    Location
    Tecumseh, OK
    Posts
    644
    Quote Originally Posted by kellyfair View Post
    And your whiskey...
    Haha! Thanks
    As for how it's holding up. Second year with this current one and going strong. Keep in mind that it is 4ft higher off the ground being mounted to the deck so it does catch the wind more than if it was probably on the ground. It does move around a bit but nothing really major. Don't put it up if it's really windy. The last one we had lasted about 5yrs but it was never covered when not in use. The fabric started to rot and a replacement canopy was over $120!!! This one I keep covered when it's it open plus I treated it with sun protectant/waterproofer.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
  14. Back To Top    #34
    ctrav's Avatar
    Join Date
    Apr 2017
    Location
    Northlake TX
    Posts
    1,236
    Very nice Revlus...how are they with a little wind?
    Thanks for the feedback!
  15. Back To Top    #35
    Revlus's Avatar
    Join Date
    Aug 2017
    Location
    Hillsborough, NJ
    Posts
    52
    Quote Originally Posted by ctrav View Post
    Today was the first time I had them up in some fairly good wind. They blew around and swayed... but there is a tiedown on the edge nearest the pole. I wasn't nervous letting em blow around.... they certainly weren't going to blow over with all that sand in the base... the pole was rock solid.
    I think they are meant to move around a bit on purpose.
    I'd put em down if a storm came through of course... but today's general windy day it was just fine.
    Today I finally noticed the ONE downside I've seen thus far. The bolts that hold the pole into the base.... I moved one today... and saw a rust spot underneath on my deck!!!! ggrrrrr..... So.... something inside is not stainless.
  16. Back To Top    #36
    Revlus's Avatar
    Join Date
    Aug 2017
    Location
    Hillsborough, NJ
    Posts
    52
    Now that I am remembering... I think it's the nuts the bolts go into.... that attach the legs of the base to the pole. Maybe I'll silicon caulk the area and see if I can keep water from getting in there. Really don't want rust stains everywhere
  17. Back To Top    #37
    ctrav's Avatar
    Join Date
    Apr 2017
    Location
    Northlake TX
    Posts
    1,236
    Great feedback and certainly appreciated!
  18. Back To Top    #38
    Join Date
    Apr 2012
    Location
    Newton, NC
    Posts
    186
    Quote Originally Posted by Revlus View Post
    In a review that I had read about our umbrella, the reviewer said that one the nuts that is welded to the base stripped when he was assembling the umbrella. Being concerned about that and also the potential for rust, I went to Lowes and bought some stainless steel nuts and bolts. I used the stainless steel bolts with the welded-in nuts and then added the stainless steel nuts and tightened them up against the welded-in nuts. I think I should be safe from rust.
    Vince L
  19. Back To Top    #39
    ctrav's Avatar
    Join Date
    Apr 2017
    Location
    Northlake TX
    Posts
    1,236
    Good job Vince..
Posting Permissions
  • You may not post replies
  • You may not edit your posts
