I have a manual vacuum brush and a 25' hose. The hose has two female ends. One female is slightly larger and, I guess, designed to go over the male connector on the cleaner. The other end appears to be a normal pool hose female. So how do I connect the hose to my female vacuum port? I have seen male to male adapters but the adapter won't quite fit correctly into the vacuum port. So, do I need to use the adapter plus another female to male hose section?
Cleaner M ) Hose F ) Adapter M-M ) Hose M ) Vacuum Port F
RANT: Why are female cuffs slightly different sizes when connected to a cleaner? Surely that tiny difference can't make that much of a difference. Why with all the hoses and adapters that are available, do they never mention what sex they are? Why are there no male to male hoses (not adapters) when there are female to female hoses? Way too frustrating.
