Thread: Back up valve continous water flow
    Jun 2017
    Warner Robins GA
    3
    I just purchase a new back up valve for my polaris 380, it worked at first, but now the back valve continuous water flow through the valve. The same issue was happening with my old valve so I replaced the valve. Now I am still having the same problem.There are new belts and the wheels are Turing but 22 rpm. I am going to rebuild the Polaris, but wanted to fix this problem first. Any suggestions. Have a hard time believing its the valve since it happen on both the old and new valve. All skimmer basket and filters are clean.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    35,035
    Re: Back up valve continous water flow
    I am not sure but here is a bump to get this infront of some more eyes.
    Mar 2018
    Eastman Ga
    1
    The 380 manual recommends correct rpm range is 28 to 32. Your unit is moving to slow, check that your getting enough water flow.
    bproosow's Avatar
    Apr 2014
    Auburn, CA
    41
    Yes, it sounds like your water flow is insufficient. The backup valve will not operate properly if the water flow is incorrect. You need to get your RPMs in the proper range, then the backup valve should work properly (cycling every 3.5 minutes). Does your cleaner run off the return line or a booster pump? If it runs off the return line, there are a bunch of things that could impact the water flow (dirty filters, diverter valve settings, missing eyeball returns, etc). It could also be an issue with the pressure relief valve or a leak in the feed hose.
    20K gallon (?) in-ground gunite pool and spa with (yet to be identified, I believe it's Pebble Fina) finish. Jandy LX gas heater, solar heat, Jandy cartridge filter, Polaris 360 cleaner (with energy filter, no booster pump), dual Jandy stealth pumps (one primary circulation pump and one for spa jets), Jandy Aqualink RS-8 controller with PDA, Pool Cover Specialists automatic cover. Taylor K-2006C test kit.
