Thread: Is this how I drain the pool?
    Jul 2017
    GA
    46
    Hi there,
    Need to drain the pool to lower CYA. Also, there’s a lot of water overflowing from the pool into spa. Pool guy says I connect a hose to the filter pump that runs spa/booster pump, run the filter, and drain the water from there.
    Water definitely comes out of the hose when I do this.
    Is this the correct way to drain the pool using the Aqualink RS-8?
    thanks,
    7,200 gallons, pebbletech, Jandy PlusHP1.0 pump
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,833
    Re: Is this how I drain the pool?
    dm,
    I am not exactly sure what you are doing, but you want to make sure that wherever you are getting the water for your pump, ... make sure it does not run dry...
    Jan 2012
    'burbs of Augusta, Georgia
    8,852
    The safest way to drain your pool is to just siphon with a hose. Leave the pump off, use the hose to start a siphon and drop the other end in a lower spot of the yard or drain. (hey, remember those days of gas shortages in the 70s? Seems a mess of folks learned how to siphon from Mom's car back then....lol)
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
