Page 1 of 3 123 LastLast
Results 1 to 20 of 43
Thread: New and overwhelmed
    Jun 2017
    Winter Haven/Florida
    125
    New and overwhelmed
    I just got my TF100 test kit today. New pool was filled last week so chlorine test produced a no chlorine reading. So to get started do I add liquid chlorine before starting to use SWG or where do I go from here?? I ran the calcium test and it is 225 so what is my next step to increase that? Didnít run the TA test, I figured I would get these 2 figured first then move on. Also considering calling the pool guy to get me up and running so talk me off the ledge!
    Finally, pump and SWG are not running yet, when do I turn them on??
    Thank you!
    Wilbur Matrix 18x33x54 AGP (15,700 gal) with Heavy Duty liner. Hayward 1.5hp Dual Speed Pump with Hayward S210 Sand filter. Aquatrol RJ salt chlorinator and Aquabot Pool Rover S2-40i. TF-100 with Salt test kit. Mark in Central Florida, Installed 03/2018
    Jun 2014
    17,807
    Re: New and overwhelmed
    First let's focus on that FC. Zero is no good. Add some bleach ASAP to get your FC to about 3ppm for now. Use the Poolmath Calculator to help. Next issue - stabilizer. New water won't have any CYA. Did you or an installer add ANY stabilizer or conditioner? If not, consider it zero and you need to add that ASAP as well. Since you'll want to use your SWG right away, the TFP recommended minimum CYA is "70" which helps protect your FC production. So as needed, add granular stabilizer using the sock-soaking method for that CYA 70 goal. Squeeze the sock often to help it dissipate then consider that goal reached. If you're nervous about going over, use the calculator to project for a CYA goal of 60, then you can re-tests in a couple days and add more if needed.
    Once the stabilizer is in the water, bump the bleach FC to about 5-7 until you turn-on the SWG and have made sure it's working okay. That's assuming you added the required amount of salt as well. By the way, do you have a good salt test kit? Once you have the SWG working, you'll back-off of the bleach and let the FC create the FC at the proper level for a SWG-pool (see the CYA/Chlorine Chart link below).
    Once you have that going, focus on the pH next - or even now really. If it's over 7.8, bring it down with muriatic acid. Never add bleach and acid at the same time though. Separate by about 10-15 minutes with good circulation. That should get you going. Let us know if you have any problems. Congrats on the new pool!
    PS - THANK YOU for being a TFP supporter!
    Also, not sure why your pump isn't on, but yes - get that water moving! Water needs to be moving to add chemicals as well. You will turn on the SWG once the required salt is in the water.
    If you have ANY concerns about what to add or how, PLEASE see the links below in my signature - especially the Recommended Chemicals link as that will tell you what each product is for, and how to dispense it.
    Jun 2017
    125
    I bought 3 gallons of liquid chlorine but it sounds like I should buy bleach instead?
    No stabilizer was added when filled so I will be doing the sock method....for the first time of course.
    I did get the salt test kit also from TF but no salt is added to pool yet. I’ll need to lookup how much to add.
    Do I need to take a day off (or a week off!) work to get all this going....it seems like a LOT!!
    Jun 2014
    17,807
    Same ingredient - sodium hypochlorite, but more expensive at the pool store. Regular bleach will work just fine in the future. You can get this going in short-order as long as you have the items handy. The sock can sock even if you're away.
    Jan 2012
    'burbs of Augusta, Georgia
    8,853
    HI there MDHKDH, I just wanted to pipe in here and mention that when you add the salt to your pool, you want to make sure the SWG is *off* for the next day or two to allow the salt to dissolve.
    This protects the device from getting a strong blast of salty water which would possibly damage it.
    If you just filled your pool your salt level is about nothing to speak of. Use Pool Math and enter current testing values in the far left hand "now" column, and then your desired levels (per the SWG manual) in the second to the left "Target" column. It will then advise you on how many pounds of salt to add. Add to the pool and brush it around to help it dissolve.
    Don't buy Clorox brand salt- we've had problems reported with it.
    Also....don't worry about adding any calcium to your vinyl pool. It doesn't need any.
    Don't let the sock filled with CYA stabilizer rest against your liner or it could stain it. Keep it free floating in front of a return or just hanging off a pool noodle or something.
    All the additions added up *might* take an hour... so only take the day off if you need a mental health day. Not needed for the pool. LOL
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Jun 2017
    125
    Hi again. So I had a bit of delay getting my equipment up and running but am finally there. I added 96 oz of chlorine and now have stabilizer in a sock. The calculator said I need about 8 lbs...does that seem right? And if so can I put 3 socks in at once... ??? Thank you!!
    Jun 2017
    125
    I read on an old post that a TFP expert put the sock in front of the jet instead of the return....and boy does that make it leave the sock in a hurry....is this ok??
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Can you elaborate on what you mean by "leave the sock in a hurry"? Is the CYA dissolving in the water or are pieces coming out of the sock? If the later, that's no good.
    That is the standard TFP recommended way to add CYA, my personal preference (if the water is warm enough!) is to get in with the sock and squeeze it and swing it around until empty.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jun 2017
    125
    It’s dissolving in a cloud so I think it is fine. I had it next to the skimmer first but making good time with it in front of the return jet. Water is a bit chilly for a dip right now...for me at least!
    Jun 2017
    125
    Maddie, thank you for the salty advice! So I now have the initial chlorine in and the stabilizer and I’m ready to add lots of salt! I have not run the SWG yet and you say not to run it for a day or 2. But I do keep the pump on and keep the salty water flowing, correct? It just won’t be chlorinating for a day or so...
    Jun 2017
    125
    Also ... at what point will I test my water now that I’ve added chlorine and stabilizer? Later today after I add the salt? Or tomorrow at some point? Sorry.... I am brand new to this and trying to find most answers without asking too many questions but am stumped on this one. Thanks!!
    Jun 2014
    17,807
    Yes, keep the pump on (low is fine) to allow everything to mix well. Now that you've added stabilizer for a projected Target, simply consider the water at that CYA. You can test it again in 2-3 days if you like. For now though, focus on your FC control as that will be most critical to avoid algae until you get the SWG going. At a minimum, test your FC once each day. I'd also recommend testing the pH daily until you know for sure it's remaining stable and not trying to shoot way up over 7.8. Hope that helps.
    Jun 2017
    125
    Ok so I should go ahead and run a test on FC and pH this afternoon? Or add salt and then test tomorrow?
    Jun 2014
    17,807
    You can test whenever it is best for your schedule, but test these two every day. Maybe later when your water stabilizes, you can back-off of the pH testing to every 2-3 days or so, but for now, test both each day. You can add salt at anytime you're ready. As noted above, it will take a couple days before the salt is fully incorporated into the water and ready for the SWG. Until that time, bleach is your pool's best friend.
    So whenever it's good for you, test the FC & pH and adjust as required.
    Jun 2017
    125
    I went ahead with a FC test just now and it came to 1.5. Seems low for having added a gallon of 10% chlorine. I thought that would bring it to at least 3...
    Jun 2017
    125
    Hope I didn’t overreact but decided to “trust the test” and therefore just added another gallon of 10%. I’m thinking the chlorine is getting used up on the Algae that was probably accumulated since filling 3 weeks ago.
    Jun 2014
    17,807
    At this point, I'd hold-off on any more chlorine. Looking back at your posts here, there have been some gaps in chlorine since first adding fresh water. It's hard to tell if you actually have an algae issue or not at this point without some specific info. So I'm going to try and slow some things down for the moment and go with some specific questions/guidance:
    - In your signature, it would help us more if you could replace the cost values with item info. For example: replace pool cost with number of gallons. The other costs can be removed if you like to save space in your signature. Also add your TF-100 to your signature.
    - It's good you added chlorine as 1.5 is much too low and an open door for algae. But when you get a chance, after allowing the water to mix for about an hour or so, I'd like for you to post the following please:
    FC
    CC
    CYA
    pH
    We'll hold-off on TA and CH for the moment. The test results above should help tell us some good stuff about the condition of your water.
    Jun 2017
    125
    Uh oh....
    FC 13 (shouldn’t have added those 2 other gallons)
    CC 1
    pH 7.2
    CYA 50 (as best as I can tell, first time running this test)
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    11,793
    That FC is fine. Not even up to shock level. See FC/CYA Chart.
    I would suggest a Overnight Chlorine Loss Test tonight. If possible.
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
  20. Back To Top    #20
    Jun 2014
    17,807
    Actually, it's a good thing you did add all that bleach. That elevated CC (over 0.5) is an indication your water is not happy. I really think your water is on the edge or getting cloudy and showing signs of algae. If you were to look at the Chlorine/CYA Chart (link below), you'll see that for a CYA of 50, the SLAM/shock level is 20, so you have plenty of room. Here's what I would recommend:
    - Keep that FC elevated for this evening at least just above 10. Test it again before bed and record. Then test tomorrow morning before the sun hits the water at compare. If you lost more than 1 FC overnight, you'll want to SLAM the water. But if you do not lose more than 1 FC overnight, you dodged a bullet. So for today keep that FC elevated, test before bed one last time (leave pump running if you can) and check in the morning. The results will tell us what we need to know.
